Wow! Those are fun! I really like the Columba on the 850T's. Always reminded me of a wooden airplane prop in the hub design.
Also the update of that design in the Perfo - so sharp. And I really like the Tellus on the XC's. It's deeper, has much more lip.
Interesting how much crossover with other makers in design - there are BBS wheels, Mercedes wheels, Audi wheels, aftermarket wheels...
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
They don't call them diving boards for nuthin'!bmdubya1198 wrote: ↑15 Dec 2020, 16:48 I'll have to check that out! Also gonna try to tuck in those bumpers... they extend WAY too far out!
When you do that, wear a face shield and DO NOT breathe any of the pressurized hydraulic fluid that will blast out when your drill bit breaks through! Some people have gotten quite sick from that.
- Has thanked: 304 times
- Been thanked: 517 times
Oh yes, I read a thread last night about that on R3vlimited. Pretty scary. All precautions will be taken!BlackBart wrote: ↑16 Dec 2020, 10:43They don't call them diving boards for nuthin'!bmdubya1198 wrote: ↑15 Dec 2020, 16:48 I'll have to check that out! Also gonna try to tuck in those bumpers... they extend WAY too far out!
- Has thanked: 1505 times
- Been thanked: 3818 times
Fired up the 1999 S70 AWD
Put battery in
Put 2 gallons gas in
PCV hose had popped off snorkel, no clamp. Pushed it back on firm
Started up and ran well
Gushed about 2 liters of gas from transfer pump side into catch pan , then slowed to drip
ME7 went closed loop in 6 minutes. Came up to temperature at 3 o'clock
All electricals work
ABS light on
Put battery in
ABS light on
- BlackBart
I don't understand the fuel leak portion of this. Break in a line? But it was running?
It's a break in the crossover pump in the P80 AWD design. Fuel is pumped from the right tank to the left tank and then it sucka the fuel from left to right and up to the fuel rail
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Inspired by another thread on here, I changed out my brake fluid today. Not to bad looking; think apple juice. Noticed that the rear bump stops seem to be disintegrating. Weird material.
1999 V70 GLT
1999 V70 GLT
The bump stops get nasty over time, almost looks like a broken up wasp nest. Nasty!
Yep, that's how they usually look!
