1999 S70 GLT winter car aquistion
- Has thanked: 1611 times
- Been thanked: 4072 times
The piston has to be pushed all the way in to install new pads, too. I use two box end wrenches as levers but finger pressure should work. If it doesn’t, the piston is seizing
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Yes, I found that out after the pads were in, but I couldn't get it over the rotor. I used a c-clamp. The boxend wrenches sounds like a good idea, since the back of the caliper doesn't provide a flat area for the c-clamp.abscate wrote: 03 Dec 2022, 00:40 The piston has to be pushed all the way in to install new pads, too. I use two box end wrenches as levers but finger pressure should work. If it doesn’t, the piston is seizing
I wonder if having the piston in all the way, would have helped me get those clips on the back in along with the ears lined up.
This is the first time I've ever had a brake hose that didn't attach to the caliper with a banjo bolt and copper washers/gaskets. Should I have put thread sealer on the end that threads into the caliper? I've looked at the Volvo manual, but didn't find anything.
I'm noticing the Akebono outer pad isn't sweeping the rotor as close to the edge as the Textar pads do. I'm so sick of these brakes. I'm struggling every step of the way, and I don't know why. Everything is just enough different that everything I know seems not to apply.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 2207 times
I have never used sealing of any sort on the threads of the brake hoses. The thread they have should be self sealing.
I have a cheap tool which is basically a threaded rod through a piece of plate and a tip on the thread to fit into the hollow of the piston. I find it a little short, but put a small socket in the piston which allows me to fully compress the piston. The other option is if there is fluid in is to crack the piston slightly open to stop the fluid hydro locking the piston preventing it being pushed home.
https://www.princessauto.com/en/disc-br ... 0002990006
You get fancier ones but at the equivalent of $6.50 US maybe worth considering for the future. I have used large pipe/adjustable pliers in the past too before I got this tool.
If the piston is fully home it should be just above the level of the caliper body by a few millimeters. With the pad fitted and fully home on the piston side the outer pad can be held in place and the whole assembly slipped over the rotor. If you are using old rotors, the rust on the edge may have built up enough to make this a challenge as it is neat in terms of space.
There is the guide on MVS to help:
https://www.matthewsvolvosite.com/repla ... iscs-pads/
or this video:
or this video:
454cid
That's what I thought, and hoped, but I woke up last night still stressing over the whole thing in general. That was one thing that didn't even cross my mind until later, and I thought I would check. I did look at the old one this afternoon, and it didn't look to have any trace of a sealant, either. Thanks for confirming.scot850 wrote: 03 Dec 2022, 15:07 I have never used sealing of any sort on the threads of the brake hoses. The thread they have should be self sealing.
I've seen those and always thought of them as unnecessary, cheaply made, tools that only did one job. However, I'm seeing that maybe I was in error. The C-clamp I typically use is unwieldy, and in the case of the Volvo calipers doesn't fit well. I think I may go ahead and buy the piston compressor.I have a cheap tool which is basically a threaded rod through a piece of plate and a tip on the thread to fit into the hollow of the piston. I find it a little short, but put a small socket in the piston which allows me to fully compress the piston. The other option is if there is fluid in is to crack the piston slightly open to stop the fluid hydro locking the piston preventing it being pushed home.
I really should get the large pliers too. When I did the serpentine belt on the 850 I used very large pliers that my uncle owns on the tensionor...didn't even mar it.You get fancier ones but at the equivalent of $6.50 US maybe worth considering for the future. I have used large pipe/adjustable pliers in the past too before I got this tool.
I did have to fiddle with it a bit today, doing the other side (just new matching pads) but it went much smoother. I did compare the two brands of pads, and the Textars are simply a bit wider, hence the fuller swept area. The Akebono pads don't go to the outer edge of the rotor, so I will get a ridge now.If the piston is fully home it should be just above the level of the caliper body by a few millimeters. With the pad fitted and fully home on the piston side the outer pad can be held in place and the whole assembly slipped over the rotor. If you are using old rotors, the rust on the edge may have built up enough to make this a challenge as it is neat in terms of space.
Thanks, I'll take a look. Eventually I'll be doing the brakes on the 850... just not as winter is ramping up.There is the guide on MVS to help:
or this video:
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Good luck with that when the time comes!
Neil
Neil
454cid
So, I decided to take the passenger side front brake apart again. The Akebono brake pads are slightly narrower than the Textar pads, but the driver's side sweeps the rotor to the edge, and the passenger side does not. I thought maybe I had something not quite right. I bought a 7mm Allen socket so I could leave the bracket on the knuckle, and just pull the caliper itself. As best as I can figure the difference in rotor sweep is differences in manufacturing from side to side and is fine.
I bled the brakes, and here's where the fun began. The bleeder on the passenger side was leaking around the the threads. All I can figure is that I must have gotten some debris in there, when I pulled the piston, or maybe the bleeder screw needs to be replaced. I "fixed" it by putting some Mega-Loc on the threads. It seems to be holding. I'll check it a few more times. I'm still getting a side to side temp difference of at least 20F, which I will continue to monitor.
I'm ready to move on from brakes.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- 2960 Views
Last post by misha
- 2439 Views
Last post by jmorman
- 1666 Views
Last post by precopster
- 1345 Views
Last post by tyrendis
- 13 Replies
- 4329 Views
Last post by matthew1
