Climate Control Nightmares Topic is solved
songzunhuang
Year and Model: 98 V70 T5
Has thanked: 2 times
Been thanked: 30 times
Post by songzunhuang »
Thanks for the pictures. I've been fighting a similar issue for years. Yes, you read that right. Years. I replaced my Evap core years ago and took apart the dash just like you. The thought of doing that again is daunting. I recall it took me a whole long weekend. So I've been living with a faulty climate control system for a long time. Luckily I live in a mild climate so on most days, it's not a big deal.
However, last weekend I took a long trip in the car and there were hours where we drove in 104 degree weather. Although the A/C was cold, the output from the vents was just a slight breeze. Not enough to adequately cool the car in over 100 degree weather. It was a little miserable in the car. So now, this has bubbled up in priority.
After your experience, do you think there is anyway to fix the cracked plastic flap ends without taking out the A/C box, which leads to a complete evac / recharge job? Thanks for any input.
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
songzunhuang wrote: 10 Aug 2023, 15:45 Thanks for the pictures. I've been fighting a similar issue for years. Yes, you read that right. Years. I replaced my Evap core years ago and took apart the dash just like you. The thought of doing that again is daunting. I recall it took me a whole long weekend. So I've been living with a faulty climate control system for a long time. Luckily I live in a mild climate so on most days, it's not a big deal.
Glad I could be of some assistance, and I feel your pain. What a nightmare the climate system can be.
Yeah, it’s not a fun job. Took me 3 days, but now that I’ve done it I could probably do it in a day or two. Unfortunately, the way the box is held together you need to pull it out of the car to replace the doors. I was able to pull the door out of the parts car without pulling the box from the car by prying the casing apart, but it’s a somewhat destructive process and not something I’d recommend if you need to reuse the box. This makes harvesting the flap you need at the junkyard easier though
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
V50M66
Post by V50M66 »
This car takes PAG 46, correct? How much should I add for evaporator and drier replacement? Seeing conflicting info online
Has thanked: 1613 times
Been thanked: 4075 times
Pag46
See why people get confused, here…
viewtopic.php?p=540983&hilit=Pag+46+oil#p540983
Amounts covered here
viewtopic.php?t=81113&hilit=Table+pag+oil
V50M66
Post by V50M66 »
And just like that, this car has icy AC!
Threw in the towel on the drier replacement, since it seems like a nightmare to replace, it was over 90 and humid today, and my patience for fiddly jobs is currently at an all-time low. I have the part in case I need it, but it’s not going in this summer at least. This car will be getting an engine out service at some point in the next year or so, so it'll likely happen then.
Charged it up with just over a lb of refrigerant (the el cheapo cans with no additives or sealers). Compressor was very much not happy about engaging properly without the zip tie shim trick, but after that, it clicked on pretty well. It blows nice and cold now and I’m quite happy with it. Time will tell if it holds, but I’m cautiously optimistic
If you had half charge or so you don’t need to replace the drier, you won’t have moisture in the system. Even better if you pump it down fir a couple of hours before charging. Full charge 750g , so one pound is short.
V50M66
Post by V50M66 »
abscate wrote: 14 Aug 2023, 06:05 If you had half charge or so you don’t need to replace the drier, you won’t have moisture in the system. Even better if you pump it down fir a couple of hours before charging. Full charge 750g , so one pound is short.
It was completely empty since I replaced the evaporator, and I have no idea how long it was empty before that since I got the car with non-functional AC. Probably need to do it but it’s not happening for now - I’ll take care of it when I pull the drivetrain out.
As for charge, it blows cold and reads properly on the gauge, so good enough for now
V50M66
Post by V50M66 »
Yeah, it was low - just wasn’t as hot yesterday. Filled it up to just under 700 and it’s much better
surfbug1
Year and Model: 1998 V70, 2006 S80
Has thanked: 41 times
Been thanked: 9 times
Post by surfbug1 »
V50M66 wrote: 10 Jun 2023, 21:04
abscate wrote: 10 Jun 2023, 00:29 There is a chassis break on 99 dampers you have to be aware of, there was a change mid year to a single cam combined damper and blend door on the driver side. Make sure your parts swaps are compatible!
Good to know, thanks! I'm assuming this break came with a part number change? The ones I put in out of my parts '99 have the same part number.
xanthefin wrote: 10 Jun 2023, 08:54
Its good at least have safety device working :wink:
Next update will have some extra items to read from ECC but i need example read out from ECT sensor from ECM live item roughly at the same time from ECC to be exact of values and if there is two instances of this with different temps, better result then.
It will have all switch knobs reading as well but i don't know what they refer per knob so only raw output value. If can slowly turn while logging on both from cold to hot i can then proceed from there convert to knob values. Some might include ERROR state too if goes wrong but App wont report it yet.
Please send then too new datalog as i thinking is there now two readings from motors like "wish to be here" and "i am here" which i included there as check for me.
For fine tuning ECC of its configurations i included too so then there shouldn't be left much any rock unturned then for ECC module as diagnostic purposes.
It is nice for sure. Got the new ABS unit in today and it works great. No more lights, and functional ABS. So at least an improvement has been made, if not regarding the climate.
Sounds good - I will send over that data when I get a chance to fully test it
hi
on the last item
was the abs module easy to install
got the same two issues
abs light
no heat directed to the floor ...blend door issues
al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
:D
V50M66
Post by V50M66 »
surfbug1 wrote: 17 Nov 2023, 05:37
hi
on the last item
abs light
al
ABS module is not horrible, but requires you to pull the intake box and tube (on turbo cars) and you need patience. Get one from Midwest ABS.
Start with replacing the blend door motor. Get one out of the same year car to make sure it works properly. Despite the same part number, there are functional differences between years.
