Re: 1999 S70 runs then dies (1Wagon post)
1Wagon
Year and Model: V70 1999
Re: Re: 1999 S70 runs then dies (1Wagon post)
Post by 1Wagon »
I never cleared the codes. Should I?
1999 V70 GLT
1981 VW Jetta Diesel (donated)
1978 Pair of Feet
2 kids (husband and son)
1 bun in the oven
1 German Shorthaired Pointer
1Wagon
Post by 1Wagon »
Also, should I send my ABS to Matty or switch it out again and keep mine installed?
1999 V70 GLT
1978 Pair of Feet
1 bun in the oven
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
Why would you switch it out again?
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
1Wagon
Post by 1Wagon »
Switch it out meaning put mine back in and send back your loaner? Does mine need to be rebuilt if I am having the same problems as before?
I never cleared codes since I got the reader. Should I?
Thanks,
Amy
1999 V70 GLT
1978 Pair of Feet
1 bun in the oven
Has thanked: 1505 times
Been thanked: 3818 times
Clear the codes, I assume your ABS light is now off? That means your original ABS unit was bad.
1Wagon
Post by 1Wagon »
Okay I will do so right now. Sorry guys, please just assume from here on out that I need every little step spelled out.
I will be back...
1999 V70 GLT
1978 Pair of Feet
1 bun in the oven
1Wagon
Post by 1Wagon »
Just came in from clearing the codes and taking a test drive. The lights on dash are very inconsistent on a daily basis. The only light on as of tonight (after installing ABS module and clearing codes) is the "check engine" light.
The car drove fine. Put in park to idle for a few, did fine. Drove back home and upon putting it in reverse with no throttle pressure, it attempted to "die" for a very quick second but didn't.
That's my update. :!:
Thanks,
Amy
1999 V70 GLT
1978 Pair of Feet
1 bun in the oven
Matty Moo
Has thanked: 1 time
Post by Matty Moo »
That isn't a loaner I sent you, it's yours. You install it and send the old one back. That's it.
2000 s70 GLT
2014 Ram
1Wagon
Post by 1Wagon »
Really? That's great news since those screw were so fun to remove and replace! :) It wasn't that bad and my pregnant belly wasn't too much in the way.
Okay well my ABS will be in the mail tomorrow.
Thanks Matty Moo!
Amy
1999 V70 GLT
1978 Pair of Feet
1 bun in the oven
Amy..you just saved 900 bucks from a dealer job.
Can you clear and give us any new codes that pop up? Also tell us when they pop up ( how many miles/time from when you cleared codes.
