Volvo 850 power loss under hard acceleration Topic is solved
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Boost leak would cause that sort of thing. TCV is a good place to start, as you said. Also check the vac lines on the turbo housings - I had two split here just last month.
- Has thanked: 311 times
- Been thanked: 817 times
Other very common causes of boost leak:
- the 20 year old hose on the IAC is cracked somewhere in it
- the 20 year old CBV diaphragm has hit the end of the road, too many flexes, look for actual holes (can see light through it) or lots of cracks where it flexes. Can be tested with a vacuum tester / brake bleeder.
- Intercooler path. So many hose/pipe junctions.
- 882 Views
Last post by Jaumme
- 1619 Views
Last post by jjlch
- 941 Views
Last post by Hardtofool
- 914 Views
Last post by bmdubya1198
- 4706 Views
Last post by June
