Aceleration problem from start Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
MALL240
Year and Model: 1991 240 2.3 turbo
Has thanked: 28 times
Re: Aceleration problem from start
Post by MALL240 »
Hi, I disconnected the O2 probe and the car works the same way, nothing strange... I'm afraid the probe must not be right...
Edit: I also bought dashboard lights (motor lights) 12V 1,2W and two uds 12V 3W
:shock:
MALL240
Post by MALL240 »
Hi, I replaced the CO2 probe and the car is doing better, along with the TPS sensor. It was a bit cold and it still backfires a bit if I give it gas hard and then some excess gasoline backfires...
I have put the bulbs of the panel and, surprise, the one with the lights comes on, the first one from the left and the second one, light and lambda...(edit)
I'm going to investigate, but I've already seen that I don't have the relay of the lights that goes down on the pedal, the lights work... so I imagine that it jumps because the relay is not there?
I don't know if I'm wearing a blue belt, I don't think I'm wearing a blue belt...
Thank you very much.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
As old as the car is, it is bound to have some air leaks which can be the source of the backfire. I suggest you smoke test the intake and exhaust system. Fix any leaks you find. Keep in mind a lot of .01s add up.
MALL240
Post by MALL240 »
Thaks Rick! the Lamda light it's the CEL no? 5 minutes and the light goes on... check OBD and i have the same 2-1-3, 1-1-3.
A lot of cables off
RickHaleParker
The unconnected cables most likely are options you do not have. Inspect them with a Loupe for scratches on the metal contacts.
Scratches = been used before. No scratches = never been used.
MALL240
Post by MALL240 »
RickHaleParker wrote: 04 May 2020, 11:58 The unconnected cables most likely are options you do not have. Inspect them with a Loupe for scratches on the metal contacts.
Ok!!!!
in the green book say too: 1-1-3 - Fault in injector (Break in lead. clogged. etc..) tha cables look news... maybe the injector
Throttleswitch; full load setting faufty. possible groundlllg short becouse the TPS sensor is new.
RickHaleParker
Got a Oscilloscope or or a Logic probe? Probe the signal on each injector.
If it was wiring I would expect misfires also.
A fresh set of remanufactured injectors is not a bad idea, US$50 - US$60 per set.
MALL240
Post by MALL240 »
I checked with a voltmeter the connections 9 and 18 to see the ohmm, I put it in 20 and the result was 003.
Buying the injectors is going to be a good thing.
Thank you, Rick. Let's see if I can get this thing to run smoothly.
nmontague81
Year and Model: '96 854, '93 945
Has thanked: 2 times
Been thanked: 2 times
Post by nmontague81 »
If it still has problems, check the air intake hose for cracks. Also check the idle air hoses for cracks and make sure all of the hoses are clamped down securely.
Maybe check the fuel lines under the hood to make sure they're not leaking.
MALL240
Post by MALL240 »
Thanks NMontague , i tried to make the smoke machine, but i did wrong... i have to try again...
