Has thanked: 1609 times
Been thanked: 4064 times
SkyVolvo wrote: 29 Jun 2021, 00:33 Started working on getting this 17-year old car bra off my S60:254E7A0B-EEC9-4C1F-88BD-BF7C7306C0CC.jpeg
Maybe some solvent or Goo Gone remover?
Car bras and car covers ( exceptions for convertibles) are indicators of small……equipment.
Following this tutorial solved the stuck key/ shifter on Shaggkira, v70 NA AT
I had to trim the plastic back to clearance the cam pivot on the knob
Good pics here
https://www.matthewsvolvosite.com/stick ... xMMw&amp=1
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Have you tried a rubber pencil eraser?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Clemens wrote: 29 Jun 2021, 00:34
bmdubya1198 wrote: 28 Jun 2021, 20:38
It sits a little lower now on the FCP Sport lowering springs lol. I just have to get used to it, the nivomats were lowered with spacers.
That is a really interesting color for an R. The stance looks good.
Thanks! It's a pretty rare color, Venetian Red.
If you haven't tried one, I highly recommend one of these rubber wheels. They are by far the easiest way to remove that stuff.
https://www.amazon.com/ABN-Rubber-Erase ... NrPXRydWU=
I had clear bra material on my hood and bumper that I took off using one of these wheels. It's great because it's effective, yet hard to burn the paint with them. Just make sure you constantly clean off the rubber debris.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
bmdubya1198 wrote: 28 Jun 2021, 20:38 And the delta link swap is done! I'll be compiling a parts list in the next few days when I get some time, but I am happy to report a successful drive to the gas station. Currently the car has no exhaust past the cat, so it's LOUD. I need to take care of that ASAP. First thing's first, I need an alignment!
Nicely done. Those two holes in the bumper are kind of empty.
Whatever shall you do for entertainment now ?
foggydogg
Post by foggydogg »
Try W40, it's probably not as aggressive as GooGoo.
Those decal removal wheels do work fairly well, but some adhesive remnants clog them up pretty quickly, so plus one on clearing debris.
foggydogg
Post by foggydogg »
mdr1220 wrote: 27 Jun 2021, 13:12 IMG_20210627_150122308_HDR.jpgI'm f***ed. One of the exhaust cam bolts snapped as I was rotating the cam to line back up with the marks.
I think you'll know more once you get the gear off. If there isn't a stub sticking out of the cam that you can get a small pair of pliers
on, try a sharp punch and a small hammer. Find a crag that you can get a little traction on, then tap-a-tap away - counter-clock, naturally. I've gotten lucky a few times.
Patience is a Virtue.
mdr1220
Year and Model: 1996 850R
Has thanked: 44 times
Been thanked: 7 times
Post by mdr1220 »
foggydogg wrote: 29 Jun 2021, 15:08
Thanks foggy. I haven't pulled the gear yet so I'll try that but I also picked up a set of left hand bits if needed. At this point all I have is patience because I'm getting a helluva education doing this.
Used to have a 01 c70 convertible
bmdubya1198
foggydogg wrote: 29 Jun 2021, 14:55
Yeah, I need to do something about that ASAP. The drone from the open exhaust is absolutely horrendous. It’s barely drivable.
Went to get an alignment today, and it’s only marginally better. The guy listened to me about using FWD specs, the sheet shows a P2. Ugh... now to go back again tomorrow and sort it out. No time for this stuff, I HATE having anyone else touch my cars. I’m too used to being the one providing service, I don’t like being the customer.
foggydogg
Post by foggydogg »
bmdubya1198 wrote: 29 Jun 2021, 16:46 ...
One of the things I miss most when my old Navy buddy closed his shop is being able to mount and balance my own tires. We had a pretty good collection of front-end alignment gear too for setting up both of our asphalt NASCAR racers. Wasn't laser-true, but good enough to get it ballpark, and a shop nearby that does nothing but alignment work would fine-tune for beers.
I just had the same alignment issue on the Rescue R ( a family-owned shop within walking distance, I know the guys' father, pretty disappointed ) which led me to buy a toe-in gauge setup from Summit. I may crawl under the car today, since it is Tropical Stupid Hot here in DE.
