2001 V70XC - 200,000 Miles Makeover Topic is solved
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Are you replacing camshaft seal or VVT hub? For t-belt alone locking tool is not needed...
As said, do marks on old t-belt and all sprockets (two camshafts, one crankshaft), remove t-belt, transfer marks to new t-belt, count teeth between marks twice, install. Use paper clips to hold t-belt on camshaft sprockets:
Here on the pic I did my first t-belt and have used a sprockets lock tool, but it was not needed at all. It turns out I did two marks on each sprocket, just to play safe.
Also, don't use Contitech belts for this engine, they are not good :)
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Yes to the paper clips! Thanks for that VTL. I’ve used the miniature Irwin quick clamps to hold the belt to the sprockets. And the paint mark on the crank pulley/belt is a must too.
The VVT hub on yours may be the spring loaded type. Mine was. Since I reused the hub the quick clamps were also a must. The new hubs aren’t spring loaded.
VTL - could you expound on why you recommended against Contitech belts?
I’d have to look, but I know I have them on 2/4 cars right now. Probably 3/4. I change them at 75-80k & have never had a problem.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
vtl
Post by vtl »
Conti T-belt is not "even": one side is thinner than the other, or something along that way. Belt tends to slide to the outer edge of the sprocket. OE belt does not do that.
Serpentine belt will eventually cost you a PS pump. It is either a bit too short, or it does not stretch/flex enough, so it requires a lot of force to put it on the pulleys, and that force remains there after the tensioner is released. One Conti belt in my car had even shredded along the treads, about 1/3 of its width. The kevlar threads made their way under the t-belt, it jumped one tooth at exhaust sprocket. I got a replacement Conti belt, was amidst painful installation process when figured out that PS pump is knocking badly. Had PS pump replaced ($380, ouch!), got Volvo belts, both. No more Conti belts, no more belt problems. Volvo serpentine belt is a much easier to install.
Yes, I've got the correct Conti belt. The shorter one wouldn't even fit, because longer barely fits.
- Pete -
Post by - Pete - »
vtl wrote: 27 Feb 2020, 21:06 Conti T-belt is not "even": one side is thinner than the other, or something along that way. Belt tends to slide to the outer edge of the sprocket. OE belt does not do that.
Very interesting, on both your T & S belt findings. Thank you again!
Your luck with car stuff sounds a lot like mine.
All the timing belts I've replaced with Conti belts have tracked right in the middle of the sprockets & shown zero wear/fraying upon replacement. I've only done 4. I'm in no way doubting you, just stating I've had different experiences. I replace S-belts at the same time I do T-belts. 2 of my PS pumps have an extremely small leak that I truly haven't tracked down to being the pump itself. Could very well be the reservoir/barb/hose junction leaking. All my pumps are silent. I honestly don't know what brand the s-belts on the cars are though. Just whatever is of European manufacture & of decent ratings on FCP.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
Has thanked: 1611 times
Been thanked: 4072 times
Possibilities are
Counterfeit part
Out of spec part sold on greymarket, aka eBay parts
Defective part
As always, check new parts before installation. Priceless information for me as I just bought a Conti timing belt forT5
vtl
Post by vtl »
Belts were bought at FCP. T-belt was ok, only riding on sprockets unevenly, I was mostly worried about my serp. belt observations (snapped, too much force put on pulleys). T-belt replacement with Volvo was more of "f-k you, Conti".
It just does not make sense to pay $10-20 less for aftermarket parts that are supposed to run for 100k/8 years.
I just measured my Conti belt thickness at 4 pseudo-random places along its length
results
No more than 0,1mm vacation across width of belt
Range of thickness long length of belt 2.5mm to 2.8 mm
I estimate the error of these measurements to be of the order of 0.1mm
This an FCP purchased belt 0845 1405 2019 (So May 2019 production?
Part number 8627484
Nicht Knicken (dont steal timing belts)
- Pete -
Post by - Pete - »
Very interesting. I’ve read peoples comments occasionally about belts being “too short” to get on the accessory circuit etc. I just always thought it was because they hadn’t positioned their serpentine belt removal tool properly.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
I think people know this, but when putting a belt on a tensioned, multi pulley system, the larger the pulley, the easier it is to put the belt on - so put the timing belt on the water pump, not the idler, and the serp belt on the PS pump, not the idler - last.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Practicing how to be calm and prepared during this project.
vtl wrote: 27 Feb 2020, 17:57 Are you replacing camshaft seal or VVT hub? For t-belt alone locking tool is not needed...
Yes, seals and hub, along with oil pump service (circus at crankshaft), hence adding t-belt, s-belt, components, and water pump to Pete's list below. I may order a la carte, not kit.
- Pete - wrote: 21 Feb 2020, 20:44
Really, all you will need to replace is the rear exhaust seal, rear intake plug, front intake & exhaust seals, then your crank seal/o-ring/gasket. Make sure to use some sealant on your oil pump bolts (under heads & threads nearest heads).
Did you get a cam locking tool? If not, mine is free for the taking now that I'm done with my task.
