RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
bmdubya1198 wrote: 02 Oct 2021, 19:16 After driving one, I'm not crazy about the overall feel. They're noticeably heavier than the sedan and wagon.
The P80 C70 is stiffer then the P80 850 S/V70 because of the wishbone frame brace on the underside. If you can get your hands on one it can be use to reduce body flex on a P80 850 850 S/V70.
I like the way my 1998 C70 handles, rock solid.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
RickHaleParker wrote: 02 Oct 2021, 19:40
The C70 subframe brace makes a big difference from what I've heard. I'd like to get one eventually.
Has thanked: 1506 times
Been thanked: 3819 times
I wanted a HPT like Elizabeth , but then the ELO Mr Blue Skies commercial came on , and I was $24500 poorer, over three years at 0% APR LESS $1500 for my repeat buyer credit
It’s a great car for picking up stray Volvo 240s
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Still hunting the oil leak on my V70. Swapped the oil for some Liqui Moly Molygen that glows under UV light.
Drove for a day, then showered the block in brake cleaner. Drove the car for 2min and got the UV light out.
The turbo side of the return line is dry, but it looks like it's leaking at the bottom :shock: I'm not sure i'm understanding gravity anymore, but i'll try to replace it anyway later this week :mrgreen:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
It will be very difficult to replace gravity. Be sure to tell us when you're doing that because it will make a real mess of things.
bmdubya1198
Just replaced that gasket and o-ring on my car.... exact same leak! The gasket on the turbo was dry, it was just leaking from that o-ring at the bottom.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Smogged my S70 which passed again! 😀
BMW 540i 2002
S70 Base 2000
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
Goupil wrote: 04 Oct 2021, 11:54 Still hunting the oil leak on my V70. Swapped the oil for some Liqui Moly Molygen that glows under UV light.
"She has no idea. If we had a black light, it would look like a Jackson Pollock painting."
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
I chased that little funny gasket for two years and two liters of tears
Don’t be a dumba$$ and wait two years to replace it like me
viewtopic.php?f=1&t=81390&hilit=Oil+return+line+o+ring
USed the P80 to solve this hard problem - worth 1000 MVS points to the first correct answer
How do you fix A RaceBeetle (2003 New Beetle Convertible) windshield washer after an hour of troubleshooting shows:
1 W/S fluid light not showing on dash
2 W/S washer swtich tests ok and with voltage
3 W/S pump tests ok
4 Wiring ok
5 Hoses ok
