In this list when did the 250 -> 500 Kbps CAN-HS transition happen?RickHaleParker wrote: 24 Apr 2021, 08:48 Updated CEM list 4/24/2021
P1 CEM Part numbers.
8690719 | 8690720 | 8690721 | 8690722 | 30765471 | 30728906 | 30765015 | 31254317 | 31327215 | 31254749 | 31254903 | 31296881
P2 CEM-B (Brick shaped 1999-2004 with K-line ) Part numbers.
8645716 | 8645719 | 8688434 | 8688436 | 8688513 | 30657629 | 9494336 | 9494594 | 8645171 | 9452553 | 8645205 | 9452596 | 8602436 | 9469809 | 8645200 |
P2 CEM-L ( L shaped and marked L 2005 - 2014 ) Part numbers.
30682981 | 30682982 | 30728542 | 30765149 | 30765646 | 30786475 | 30786889 | 31282457 | 31314468 |
P2 CEM-H ( L shaped and marked H 2005 - 2007 )
30786476 | 30728539 | 30682982 | 30728357 | 30765148 | 30765643 | 30786476 | 30786890 | 30795115 | 31282455 | 31394157 | 30786579
Notes
30759114 listed as a L shaped P2 CEM unable to determine if it is a CEM-L or CEM-H.
Also does CAN-LS always work at 125 Kbps, on all those listed CEMs? I'm thinking of querying CEM part.number via CAN-LS and configuring CAN-HS, shuffle order, etc based on that, so the cracker would be essentially a plug'n'play.
