454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 128 times
Post by 454cid »
Went back to look at the V70 that I saw previously. I was able hear it run and pull codes. Had a transmission code or two, low signal something or other. It also smoked terribly when warm. I also found that the throttle was known to stick wide open.
I passed.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1836 times
Been thanked: 1709 times
Most likely valve stem seals and pcv needing done. Can't recall if it was a turbo?
The throttle sticking if a 98 with wire throttle to gas pedal it has either got a broken strand in the inner cable, cable needs lubed internally and the throttle mechanism needs cleaned and lubed.
Trans issues could be anything without knowing more details. Does the trans work?
454cid
Post by 454cid »
scot850 wrote: 09 Jun 2022, 08:40 Most likely valve stem seals and pcv needing done. Can't recall if it was a turbo?
NA, like my 96 850 sedan
It did have smoke coming from the dipstick tube, but I didn't see any or feel much "breeze" coming from the oil filler, which I thought was odd. Also had smoke coming out of the exhaust flex joint area.
It didn't seem to be sticking when I looked at it, but the guy said he had sprayed something on the linkage to free it up. His theory on the smoke was that the throttle stuck and someone let the engine REV for too long. He said he almost hit the building the first time he put it in gear because he wasn't expecting it. It's an auction house that has the car.
I was told not to put it in gear because of the throttle, and while curious, I had pretty much already made up my mind that I was going to pass.....I'd like to have a wagon, but I can wait for a car that's in a bit better condition.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
I think that is what I would do too. Eventually a better example will come along.
Good Luck!
Has thanked: 1497 times
Been thanked: 3810 times
Good job passing on the beater. A car with that many problems Is free. If you can’t drive it to test stuff, it’s a parts car.
454cid
Post by 454cid »
abscate wrote: 10 Jun 2022, 04:10 Good job passing on the beater. A car with that many problems Is free. If you can’t drive it to test stuff, it’s a parts car.
The auction house actually doesn't allow test drives at all. The only thing allowed is pulling forward, and then backing right back into the parking space. That's how I bought my current Volvo.... same auction house. I'm sure if I pushed the subject, I would have been allowed to put it in gear, as I was looking/hearing about the car it became less important to me :lol:
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Engine's out of the C70, not without a good amount of swearing.
AC compressor bolts are still a pain to get to, lower gearbox coolant line nut was so stuck I ended up cutting the line and i'm really pushing the 250kg limit on that hoist :mrgreen:
Last inspection noted damage to driveshaft boots, wasn't wrong, both side were like that
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
I like your parts and tools wagon.
Goupil
Post by Goupil »
saves me a few steps from having to walk back into the garage haha
and easier to pack everything when it starts raining, which happened a few times
454cid
Post by 454cid »
Goupil wrote: 10 Jun 2022, 13:44 Image
I love that stone building, what is it used for?
I also love how our hoods will open like that.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
