Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Sveedy wrote: 19 Jun 2022, 19:29 Very cool on getting things back installed. Great feeling, I know.
And your right - somewhere around 4:00 am the answer will probably come to you.
4:00am didnt help, but walking around the garage did :lol:
The car pops and run like shit for a second then stalls again. I replaced the cam seal behind the distributor, and looking at the rotor plate from the other engine it seems possible to install it 180° off :? that wouldn't help :mrgreen:
Weather isnt on my side, it was 90°F on saturday and 54° and rainy on sunday !
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
Goupil wrote: 20 Jun 2022, 11:22
I enjoyed 102F today. Just got my garage AC working yesterday and installed garage door insulation panel today. Its keeping my garage at 75F all day.
Has thanked: 1500 times
Been thanked: 3812 times
You have to be a real monkey mechanic to do that
viewtopic.php?t=94920&hilit=1998+start
Has thanked: 1839 times
Been thanked: 1709 times
I like all that insulation you are adding to the garage doors. Looks really neatly done!
Although I have insulated doors, it may be worth considering adding that insulation for our winters. Mind you, the bigger issue is getting the seals to work around the doors in strong winds from the west. It just blows the doors back from them.
Do the panels add a lot of weight to the doors?
Thanks,
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
“Garage A/C” is a new one on me! But I’ll admit in the summer I need some fans blowing!
Turbojeppe
Year and Model: 95 Volvo 850 T-5R
Has thanked: 1 time
Post by Turbojeppe »
Today I hunted some gremlins on the yellow one.
  • New vacuum lines around the turbo.
  • Off with the plate and back with the oem BOV.
  • Swapped the turbo inlet pipe to one with an intact PCV nipple. (the small one was broken on the old inlet)
Hopefully I'll get some results, gonna test drive tomorrow. Boost is down a few PSI and I get oil-smoke in random left hand turns.
Volvo 850 -97 170hp GLT Estate [Scrapped]
Volvo 850 -95 230hp T-5R Estate 2.0L
Volvo 850 -96 170hp GLT Estate [Scrapped]
Volvo 850 -95 140hp SE Saloon
Volvo 850 -94 225hp T5 Estate
All mannys
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
I'm jealous... I could use some real garage AC! I have a little window unit in my garage, but it doesn't work all that well when I refuse to close the garage door :lol:. I guess I have to choose...
ZionXIX
Post by ZionXIX »
scot850 wrote: 20 Jun 2022, 19:00 I like all that insulation you are adding to the garage doors. Looks really neatly done!
Thanks,
They are really lightweight Styrofoam panels with a plastic sheet on one side. Honestly they all weigh just a few pounds together.
Check out these special tracks that push the door against the frame. I wish i had these.
https://thermotraks.com/
ZionXIX
Post by ZionXIX »
bmdubya1198 wrote: 20 Jun 2022, 20:43 I'm jealous... I could use some real garage AC! I have a little window unit in my garage, but it doesn't work all that well when I refuse to close the garage door :lol:. I guess I have to choose...
I went with a mini split 18,000BTU unit for a 3 bay garage. I installed it myself as it comes with the 410a pre charged. I would probably just hire someone next time. But you only need a 3 inch hole to run lines through vs a window unit needs a much larger opening. I just refuse to open the door unless I need to move something too large to move through the house.
bmdubya1198
ZionXIX wrote: 20 Jun 2022, 21:12
Nice! I bet it’s nice and comfortable in there now! The weather was nice here today, but we’re getting close to 100 again for the rest of the week. It makes the garage miserable.
