- Has thanked: 317 times
- Been thanked: 531 times
Speaking of mounts... replaced the trashed iPd torque rod bushing with a Powerflex today. Much better!
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Changed out the voltage regulator from a worn out bosch to a transpo ib520. Did an oil change and transmission drain and fill. Have to tackle the exhaust next week.
Full load readings went from 12 < on old reg to 12.5 V with all loads present. Had a .3 drop on battery + cable so that needs to be dealt with eventually. Atleast my battery will consistently charge under normal loading.
2008 S60 2.5T Auto (Sold)
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I have one to change out too.... not sure if it's the same part number or not. I also need to to the oil and ATF.yanga001 wrote: 01 Jul 2022, 14:50 Changed out the voltage regulator from a worn out bosch to a transpo ib520. Did an oil change and transmission drain and fill. Have to tackle the exhaust next week.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1613 times
- Been thanked: 4078 times
FCP had Bosch on sale for about $44 last week?
It's only a year or two old, believe it or not. I'm really disappointed by the quality of the iPd bushing. It was definitely vibrating more than it was before. I felt like it was feeling kinda harsh for a while, then I noticed the chewed up bushing while I was doing other stuff under the hood and it all made sense. I still haven't driven it yet since replacing the bushing, but I'll drive it today and see how much better it is!
They do, but not a whole lot. My car has more NVH than the typical P80 because I have the poly bushings on this torque rod, the lower torque rod, and delrin subframe bushings. I don't mind it, but some may not like it. I'm sure with an auto trans, it would be a little annoying sitting in gear on the brakes.kallekula wrote: 01 Jul 2022, 12:32 Im vary of those never-ever-breaking powerflex or whatever the material/brand. Doesn’t it cause engine vibrations?
After putting poly transmission mounts on my E46, nothing like this will phase me. Those genuinely made me think I had a severely unbalanced flywheel or something else horribly wrong. The vibrations were unbearable. Put some stock rubber ones back, the car feels great now. I would never recommend those poly trans mounts on a BMW!
Bob Morton
- Year and Model: 1998 S70 T5 SE
- Been thanked: 8 times
454cid
Drove it to get coffee..... will get it washed later today.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 116 times
While trying to diagnose other things, I noticed my battery voltage was quite low, even when the car running.
It would appear that someone (
) forgot to tighten the alternator terminal bolt, that would do !
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
