The abilities of "previous owner" to do things wrong will never fail to amaze me.
Name that rusty part
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 71 times
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
This sort of abject destruction is why I started this thread. The less identifiable, the better.jsrnsis wrote: 21 Jul 2023, 23:47 This might be cheating but it's still something you could figure out:
#1 - Inside the rear (right?) frame rail with the bumper removed.
#2 - Rear left caliper outer piston. What happened to that boot?
#3 - Don't know, these cropped images make it tricky.
#4 - Those pins suggest it's the remains of the rocker panels. Wow I have to check mine.
#5 - Don't know, I'm scared of P80 AWD.
FireFox31
- Has thanked: 2207 times
I agree with Firefox on #1,2,4. #3, no idea but home made fix. Almost looks like an ABS sensor. #5 is a broken Prob-shaft center mount.
jsrnsis
FireFox31 wrote: 23 Jul 2023, 15:31This sort of abject destruction is why I started this thread. The less identifiable, the better.jsrnsis wrote: 21 Jul 2023, 23:47 This might be cheating but it's still something you could figure out:
Bingo on 1,2, and 4, even got the correct sides. No idea how someone could let a caliper get that bad, but would you believe that the pads and rotors were new? The thing was locked up solid.scot850 wrote: 23 Jul 2023, 19:38 I agree with Firefox on #1,2,4. #3, no idea but home made fix. Almost looks like an ABS sensor. #5 is a broken Prob-shaft center mount.
#3 is the bottom of the rear shock mount. They snapped the head off the original bolt, drilled it out completely in the wrong spot, just stuck a bolt in the hole that now spins freely, and then used two sheet metal screws.
That last picture is what happens when the center support mount catches a trailer when unloading, ripping it right off the car. It was described as simply needing a new center support bearing.
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
It doesn't necessarily need a trailer scrape to end up on the ground... Everything else under the car was spotless; when I pulled the last two bolts, the whole mess hit me in the face. I have carefully preserved all of it for Dr. Abscate's next visit.jsrnsis wrote: 21 Jul 2023, 23:47
And finally, guess what the seller described this rusty part carnage as in his description: (best viewed upside down...)
jsrnsis
Car part or civil war battlefield metal detector find?
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
Looks like a seriously deceased Bilstien shock/strut!
Eek!!
Eek!!
- Has thanked: 1611 times
- Been thanked: 4072 times
Almost had me guessing fuel filter but my Spidy Sense tells me ancient near end of life AC accumulator-drier
- Has thanked: 987 times
- Been thanked: 1077 times
Monroe shock remains. (Yellow paint)
- foggydogg
This is too easy,
One number was 9434431, the other one MIGHT have been 9161065, replaced by 9470686,
but naturally I didn't want to do that.
After a week in molasses Chelation Camp, Ospho and rattle-can, And as always, iPhone 7+ takes sh!tty pics, from birth.
- 4407 Views
Last post by 93Regina
- 1761 Views
Last post by oragex
- 717 Views
Last post by voom8
- 2362 Views
Last post by seanj
- 23 Replies
- 6363 Views
Last post by Phantomphixer
