1995 850 t5-R
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
August 22, 2106 - 281,694miles
Replaced OEM rubber boost hoses with silicone hoses from FCP
polskamafia mjl
August 31, 2016 - 282,XXX miles
Replaced shattered glass in driver side mirror
polskamafia mjl
October 20, 2016 - 282,XXX miles
Exhaust hanger welded at Red Run Exhaust
polskamafia mjl
December 10, 2016 - 284,285 miles
Replaced inner and outer CV boots on passenger side; regreased joints with new grease
December 28, 2016 - 284,543 miles
Spliced in new electrical plug for driver's side turn signal
polskamafia mjl
January 26, 2017 - 285,285miles
Passed inspection at Your Inspection Connection
polskamafia mjl
March 2, 2017 - 286,029miles
Trailing arm bushings replaced and 4 wheel alignment completed at Swedish Motors, Inc.
Driver side spring seat replacement was recommended
polskamafia mjl
June 9, 2017 - 288,XXXmiles
Front driver and passenger rotors resurfaced
Driver side rotor was the most warped which is odd because that caliper is just over a year old
After bedding the brakes the driver side rear caliper has begun to stick
Disassembled and cleaned caliper and pads but the results have been underwhelming so far
polskamafia mjl
August 16, 2017 - 290,015miles
Oil change with Shell Rotella T6 5W40 synthetic oil
Mann oil filter
New crush washer
Oil sample collected for analysis
Front tires are worn to wear indicators
Steering feels sloppy at speeds above 50mph
Vibrations become apparent at these speeds as well
polskamafia mjl
September 27, 2017 - 290,418 miles
Replaced driver side rear brake caliper with rebuild ATE caliper from FCP
Bled driver side rear caliper with DOT 3/4 brake fluid
polskamafia mjl
October 27, 2017 - 291,056 miles
Towed home after no start - 10/25
Fuel pressure seems good so I suspect spark was the issue; probably caused by crank position sensor
Cleaned and reseated the electrical connector multiple times
Car started in warm weather today
Replaced washer reservoir and pump
Cleaned IAC electrical connector due to continued high RPM's with foot off gas after cold start
