1998 V70 Timing belt, cylinder head work 330k miles!
5rivers
Year and Model: V70 1998 T5
Been thanked: 15 times
Post by 5rivers »
Just what I wanted to hear, precopster! Thank you!!
Glad the pics are useful, clifford06! Sorry to hear about your 2.3 motor. Good luck with it.
Still in the process of cleaning the cylinder head. Will likely being lapping valves tomorrow.Will post more pics as I go along...:)
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
5rivers
Post by 5rivers »
Ok, so I am at the point where I can begin lapping the valves. When lapping valves, they need to move up and down with little resistance, but there must be some resistance (i.e., from valve seals) to make sure the valve is sitting as perfectly as it can without any leaks. So, my question is do the valve seals need to be installed before beginning the lapping process? Appreciate your replies!
5rivers
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
5rivers wrote:So, my question is do the valve seals need to be installed before beginning the lapping process?
No. If you are changing the valve guides those should be changed first but the seals don't make any difference on the valve angle through the head. Besides, they just add rotational resistance as you are lapping.
5rivers
Post by 5rivers »
Thanks for your reply on the valve stem seals, Lee!
I checked the valve guides and the valves in each guide have no wobble, so no need to change the guides (that makes me very happy!).
5rivers
5rivers
Post by 5rivers »
Here are some pics of cylinder head after soaking and brushing, and more soaking and brushing, etc! Its as clean as I could get it with being overly OCD!!
Top of cylinder head.rtfd.zip
(40.93 KiB) Downloaded 230 times
Bottom of cylinder head1.rtfd.zip
(132.76 KiB) Downloaded 206 times
Closeup1.rtfd.zip
(119.91 KiB) Downloaded 207 times
Closeup2.rtfd.zip
(121.31 KiB) Downloaded 186 times
Closeup3.rtfd.zip
(81.86 KiB) Downloaded 184 times
5rivers
5rivers
Post by 5rivers »
Opps, saved the pics incorrectly.
5rivers
5rivers
Post by 5rivers »
Top of cylinder head.jpg (39.98 KiB) Viewed 1446 times
Bottom of cylinder head.jpg (128.49 KiB) Viewed 1446 times
5rivers
MrPc
Year and Model: 850R 1996
Been thanked: 2 times
Post by MrPc »
Nice pics, 5rivers. Since you have the head off and in your hands, would you mind taking a look at the exhaust stud closest to the back of the engine? (ie driver's side, possibly the one that can be seen in your 2nd photo.) Can you tell if it penetrates into an oil passage or anything like that? I've been dealing with a leak in this area, and it would be good to know what is in there. Thanks!
Red Red '96 855R, 169k
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
MrPC,
Oil leak on driver side near the exhaust stud: I can bet it comes from the Front Cam Seals.
See my DIY on TB SB WP overhaul, I specifically talked about tools (PVC coupler) and Corteco seals.
Has thanked: 1610 times
Been thanked: 4068 times
This stud oil leak is well documented in the other thread. Sealing the stud with permeated stopped it for a few months
