Parting out 1999 Nautic Blue V70 auto NA wagon DEC 2016, location Albany NY
Has thanked: 1613 times
Been thanked: 4077 times
kklepack wrote: 28 Jul 2020, 11:59 Looking for Volvo Door Lock Assembly - Genuine Volvo 8626183 front driver side.
I probably have this in the black handle only, I think I sold the Nautic Blue one.
Does the piece you need come off the exterior handle?
On edit...looked it up, it does come off.
kklepack
Year and Model: 2016 XC60
Has thanked: 12 times
Been thanked: 5 times
Post by kklepack »
abscate wrote: 01 Aug 2020, 05:48
Matter fact I think I need Door Lock Actuator Motor only and not whole assembly . I will also hit JY around me to look for it.
kklepack
Post by kklepack »
Found it. No longer in search for it.
Someone has dibs on the ABS PUMP when I find it
abscate wrote: 29 Mar 2019, 05:27 Lock module controller sold
Alternator sold
Ac compressor sold
abscate wrote: 04 Nov 2018, 05:41 ABS PUMP SOLD
abscate wrote: 21 Feb 2017, 13:56 Car has been picked and crushed, latest Inventory of parts and pricing are as follows
Description Volvo Part Number Note Base Part Tested
30 day money back warranty, customer pays return shipping 30 day warranty, we pay return shipping on receipt of part. We install and test part before shipping.
Format is:
Description Note Price untested Price/tested
Call for details. Priced to market - people with good karma are free to PM for deals.
Headlight Switch SOLD Qty 3 20 $27
DIM 9472521 50 $67
ECC Dash Fan 18.75 $25
STC 6.25 $8
Function Swtich 6.25 $8
Rear Defrost Switch 6.25 $8
Passenger Airbag 9467008 Qty 3 258.0225 $344
Ignition Coil Qty 5 12.5 $17
Driver Airbag 9206137 Qty 3 206.3975 $275
Glove Box 25 $33
Brake Booster 9203843 Qty 2 145.4475 $194
Radiator Cooling Fan 9497929OE 101 $135
BOSCH ALT BR-14 Qty 2 91.25 $122
ABS Pump Motor 8619543 295.5 $394
DENSO ECU 25 $33
TEMIC TCU 25 $33
Horn High MIXO 9169550 Tuned by the Albany Symphony Orchestra to A440 11.25 $15
Horn Low MIXO 9169551 11.25 $15
Steering wheel, charcoal 25 $33
Air filter box 50 $67
MAF DENSO 59 $79
Air Bellows 9155453 10.75 $14
ECC damper 9134729 45.8225 $61
ECC Fan Blower 9171429 36.75 $49
ECC Resistor 9166694 34.5 $46
Turn Signal Switch 9162455 Qty 3 25.5 $34
Immob Ring 9442461 12.5 $17
Ignition Swtich 8650054 Side connector 15.25 $20
Starter 8251551 Like New 81.25 $108
Intake CVVT 58.75 $78
ECC Damper 9142629 Qty 4 43.75 $58
ECC Control Unit 9171800 Qty 2 118.75 $158
Relay 9148300 Timer 6.25 $8
Relay 9148748 Seat Belt 6.25 $8
Relay 9128136 6.25 $8
Relay 9472575 6.25 $8
Relay 9169611 6.25 $8
Rear Wiper SOLD 50 $67
VVT Solenoid INTAKE F34711502 Qty 2 31.25 $42
VVT Solenoid EXHAUST F34711602 Qty 2 31.25 $42
SCH16 Stereo 0 $0
ABS Module 9472100 50 $67
Fuel Rail w % injectors 62.5 $83
Power seat switch 9206693 46.25 $62
Coil on plug wire harness 50 $67
Dash Cover 9127584 50 $67
Headlight Both Sides 71.5 $95
Tailight Both sides 62.5 $83
Turn Light Both sides 20 $27
Turbocharger TDO4L-14T 274.25 $366
BEHR Oil cooler 8677974 38.75 $52
Master Cylinder 9203845 61 $81
Ignition Coils 12.5 $17
BOSCH BR-10 ALT 91.25 $122
Wiper Motor Front 20.25 $27
Power steering Pump 8251734OE 132 $176
Electronic Throttle Body 9186793 125 $167
Headlight wiper motor 390206955 37.5 $50
Headlight wiper motor 390206962 37.5 $50
AC COmpressor 8708581 87.5 $117
Short Block SOLD 450
Cylinder head SOLD 100
Driver Door SOLD
Passenger door SOLD
Rear Door, Left SOLD
Tailgate SOLD
Bump for last time, pm for availability of parts
