102K miles on new PCV. I can replace it, but it won't solve my stumble/stall issue when the engine reaches temp.bmdubya1198 wrote: 05 May 2020, 17:34 If you haven't done the PCV yet, I recommend doing that very soon as well as replacing the rear cam seals.
Engine died while driving and won't start. Topic is solved
- valvolvo70
- Year and Model: 1998 V70 T5 249K
- Has thanked: 10 times
- Been thanked: 8 times
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It won't.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- valvolvo70
Initial start up, the engine runs smooth, I can drive it and responds normal. This is what it sounds like AFTER reaching temp (temp gauge needle centered). Higher rpm's, stumbling is not as noticeable. Eventually the engine will stall, especially in gear.
stumble.mov- (8.23 MiB) Downloaded 125 times
- Has thanked: 311 times
- Been thanked: 817 times
If you unplug the MAF when the car is off and then drive around for a while, does it still stumble when the engine gets hot?
1998v70xcbill
- Year and Model: 1998v70xc
- Been thanked: 3 times
You have oil in the distributor. clean the cap and electrodes. The cam seal probably fell out, remove the rotor and take a look.
- valvolvo70
Unplugged the MAF and started it, immediately stumbled. Plugged MAF back in, still stumbling bad...didn't need any time to warm up.erikv11 wrote: 06 May 2020, 11:34 If you unplug the MAF when the car is off and then drive around for a while, does it still stumble when the engine gets hot?
- Has thanked: 316 times
- Been thanked: 531 times
No, the PCV probably won't fix this, but keeping the cam seals in place and oil off of the distributor might help. I don't know that it's the root cause of this issue, though.
- valvolvo70
This is unusual. The car should run just fine with no MAF.valvolvo70 wrote: 06 May 2020, 12:19Unplugged the MAF and started it, immediately stumbled. Plugged MAF back in, still stumbling bad...didn't need any time to warm up.erikv11 wrote: 06 May 2020, 11:34 If you unplug the MAF when the car is off and then drive around for a while, does it still stumble when the engine gets hot?
I missed the bit about the oil and condensation in the cap. Definitely need to clean it out and more importantly check the cam seal. This is almost certainly the cause of the problem. As suggested cleaning the PCV may help prevent recurrences.
- misha
Yes....if the Maf is bad.
This shows that the problem is not the MAF.
I suspect that it is the oil in cap & rotor like allready suggested...but could be something else which makes problem when it's heat soaked.
Something like relay,probably ground or b+ cable.
I would suggest a voltage drop test across cables or simple charging voltage test across battery terminals with a multimeter when problem occurs.
Let somebody to keep the gas pedal,not allowing the engine to die while you check charging voltage across battery terminals.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1264 Views
Last post by FL850_1997
- 3602 Views
Last post by lummert
- 19 Replies
- 3921 Views
Last post by cn90
- 14 Replies
- 3443 Views
Last post by dj_v70
- 1556 Views
Last post by sleddriver
