Volvo 2.5T AWD 2003 Automatic delay 3 to 4
greffel
Year and Model: 2003 S60
Has thanked: 11 times
Been thanked: 8 times
Post by greffel »
If it's not possible to travel this summer due to Covid I might go for this rebuild to have some fun :)
What you are saying is that my transmission is no easy fix?
Could there be even a slight chance that the B4 cover/pin or spring is moving to slow to get this kind of flare 3 to 4 ?
Polestar 2 - All electric daily driver :shock:
S60 2.5T AWD with a little bit more power :evil:
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
greffel wrote: 24 Mar 2021, 10:45 If it's not possible to travel this summer due to Covid I might go for this rebuild to have some fun :)
Here's something you could check as a slight chance effort. When I put my transmission back together I had a 2-3 and 3-2 shifting problem (needed adaptation) and I wanted to check the B4 servo movement spec again. Here's what I did to try and determine if the B4 servo movement spec was correct. No guarantees how accurate this is but the measurement numbers looked reasonable to me. I think it will at least give you an idea if the B4 servo movement spec is close or not.
B4 servo spec measurement.pdf
(519.02 KiB) Downloaded 126 times
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
I'm half way down tearing it apart, struggling to separate halves (without waking up the kids). So far mechanically everything looks alright, besides some overheated steel, plus apparent clutch pack failure in torque converter.
The transmission has ~220k miles, it was refilled with fresh ATF once at 110k. When I got it at 217k, I did a couple of drain&fills, it was yuck! The car was driveable, however the shifts quality was according to ATF change intervals.
firstv70volvo
vtl wrote: 24 Mar 2021, 21:17 I'm half way down tearing it apart, struggling to separate halves (without waking up the kids). So far mechanically everything looks alright, besides some overheated steel, plus apparent clutch pack failure in torque converter.
Good that you're not finding any obvious mechanical damage. If the steels look overheated then they should be replaced. In the rebuild kit that I linked to it did not include the steels. I took a gamble the steels wouldn't be needed and that turned out to be the case with my transmission, frictions were worn but not to the point of damaging the steels plates and no overheating.
From the photo I see you're working on a 51SN with the single sun gear shaft. This reduces the number of bushings you'll need to check or replace by two.
I've been working on my notes about the bushings and here's what I have so far.
busings.pdf
(988.49 KiB) Downloaded 166 times
Check all the bushing carefully and don't be surprised if many of them are fine. The only bushing I saw that had any signs of being worn was the bushing in the oil pump housing.
For Greffel I am going attach the link below again as a method for checking his 3rd gear band servo piston travel with his transmission still in the car. If you have the opportunity with the transmission you're working it would good to know the length of the rod check measurement method when the 3rd gear brake band is compressed and the length of the servo pin in your transmission. He wanted to know if there was any slight chance of doing anything else to deal with the 3-4 flare before having to tear into his transmission.
(519.02 KiB) Downloaded 133 times
greffel
Post by greffel »
You have given me a little bit of hope. I will try to find some time this weekend to check it.
So I just have to find something to push in the hole and measure it.
A good workshop that specialists in gearboxes should have a linger pin if needed i guess..
vtl
Post by vtl »
firstv70volvo wrote: 25 Mar 2021, 08:28 Good that you're not finding any obvious mechanical damage. If the steels look overheated then they should be replaced. In the rebuild kit that I linked to it did not include the steels. I took a gamble the steels wouldn't be needed and that turned out to be the case with my transmission, frictions were worn but not to the point of damaging the steels plates and no overheating.
On another resource I was pointed to the fact the "overheated" parts are just tempered, so they come new in black/bluish color. So all is good. Didn't measure the thickness of frictions nor bushing bores, but all looks to me. The whole transmission probably was in a very good condition until torque converter decided to give up.
firstv70volvo wrote: 25 Mar 2021, 08:28 From the photo I see you're working on a 51SN with the single sun gear shaft. This reduces the number of bushings you'll need to check or replace by two.
busings.pdf
The bushings look good. I'll measure their bores today and decide if they need a replacement. Thanks for the link!
firstv70volvo wrote: 25 Mar 2021, 08:28 For Greffel I am going attach the link below again as a method for checking his 3rd gear band servo piston travel with his transmission still in the car. If you have the opportunity with the transmission you're working it would good to know the length of the rod check measurement method when the 3rd gear brake band is compressed and the length of the servo pin in your transmission. He wanted to know if there was any slight chance of doing anything else to deal with the 3-4 flare before having to tear into his transmission.
You can get a whole new piston from GM, but it is not cheap ($80'ish). I decided to remove shim 2 (1.73 mm) from the piston assembly, and it help to remediate progressing jolts quite a bit.
firstv70volvo
Here's a good Youtube video I haven't seen before on the assembly of the AW55 transmission.
firstv70volvo
greffel wrote: 25 Mar 2021, 09:23 You have given me a little bit of hope. I will try to find some time this weekend to check it.
Yes, a metal or even wooden rod dowel that will fit inside the servo pin bore hole. Push on it firmly to compress the 3rd brake band and mark it carefully on the inside edge of the bridge piece across the opening. I'll be curious what this measurement is as I think it will give you an idea if your way out of spec or not on the servo piston travel. For more accuracy is might be best to taper the end of the rod similar to the servo pin so it fits in the brake band the same.
firstv70volvo
firstv70volvo wrote: 25 Mar 2021, 10:38
Edit I've revised the method previously described to simplify and make more accurate.
Here's another method that's probably more accurate and easier. I tried it on another transmission. Just remove the B4 server cover, piston and remove spring then re-insert the servo piston and use the handle of a rubber mallet or anything with a very flat bottom handle to push the piston and compress the 3rd band with the end of the handle. I put a piece of masking tape on the handle to mark the edge of the case when the band is fully compressed. The bottom of the handle must be flat and you need to be sure the handle is pushing on the servo pin in the center of the piston. You then measure, with vernier caliper's, from the bottom of the handle to the mark on the tape, for accuracy this is why the handle bottom needs to be very flat. In my case the distance between the end of the handle and mark was 17.6mm.
You then subtract 12mm from the measured value and this provide the B4 Servo piston travel. 17.6mm - 12mm = 5.6mm based on my measurement. Slightly on the low end of the spec but there will be some measurement error in the process. As the 3rd brake band wears the measured value will increase.
Spec is 5.76mm to 6.76mm so you should expect a measurement using the method described of 17.76mm to 18.76mm to be within spec.
vtl
Post by vtl »
Measured wear in bushings:
Oil pump:
0.0021"
0.0010"
Some shaft (my AW55 internals names knowledge is weak):
0.0039"
0.0013"
Can see a fifth, larger bushing on pictures in the internet, however didn't see it yet in my parts bin. But I didn't split up everything yet.
Also differential preload looks good. Didn't measure it properly with a torque wrench, but can compare it my old broken angle gear (stripped splines) and the diff preload is more or less like that. At least it is present. Not going to reshim the bearing race.
