Has thanked: 1836 times
Been thanked: 1709 times
Chuck, check the engine mount and torque mounts while in there. They are often the reason for the radiator failing in that area.
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
scot850 wrote: 28 Oct 2022, 09:55 Chuck, check the engine mount and torque mounts while in there. They are often the reason for the radiator failing in that area.
They were all replaced when I did the manual swap a couple years back, so I doubt that's the case. I think it's just an old radiator.
Fair enough, but worth asking. All my radiators failed on the RHS seam between the aluminum fins and the plastic end caps and below the top hose connection.
If you used Volvo OE mounts then you should be ok. Anything else who knows these days?
Good luck!
Chuck W
Post by Chuck W »
scot850 wrote: 28 Oct 2022, 14:01 Fair enough, but worth asking. All my radiators failed on the RHS seam between the aluminum fins and the plastic end caps and below the top hose connection.
Yeah, they were Volvo OE.
This car has also killed a deer and a Prius, (Which is what eventually led to the XC nose swap), so I'm surprised the radiator hasn't started leaking before now.
:shock: :lol: :lol:
You haven't named it Christine by any chance...............?
Has thanked: 1497 times
Been thanked: 3810 times
Killing a Prius is considered a mercy killing …
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Found why the top of the rocker cover was getting filled with oil a lot faster than usual, despite a good gasket on the filler cap. Operator error :lol:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
You need a really slim hose clamp to get a good hold on that hose. Pretty bad location for that!
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
I've checked all brakes, disassembled everything, cleaned and rebuilt them. I've discovered a leak under the gearbox.
bmdubya1198 wrote: 29 Oct 2022, 12:20 You need a really slim hose clamp to get a good hold on that hose. Pretty bad location for that!
oetiker oetiker….. Oetiker
