foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Took well over an hour, mostly because I don't bend or fold in enough places anymore, and I was adamant about not pulling the seat out again.
This car is getting towards the end of its string with me.
I'll start a separate thread on trying to fab a fix on the broken piece.
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
bmdubya1198 wrote: 17 Dec 2022, 16:29 Love the Thunderbird! 2.3 or 5.0?
Originally a 5.0 when I bought it back in '96. Been a 2.3T for a long time now, though.
Have a list of projects to go through on it, but it's 3rd in line behind the 850 and the '85 LTS.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 128 times
Post by 454cid »
brunocerous wrote: 17 Dec 2022, 17:12 I finally undid the two radiator mounting bolts with a combination of a grinder, oscillating tool and drill. It wasn’t pretty, and I’m not proud of what it looked like at the end, but it was a relief. 5F760CFA-0598-4E77-A362-6B9089A9403C.jpeg86AF0006-4A58-44C1-8D53-B43B52345393.jpeg
Where did you get the constant tension band clamp for the upper hose?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1502 times
Been thanked: 3813 times
You can’t clamp over a paper label, Bruno…it’s …just…..wrong.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
abscate wrote: 18 Dec 2022, 00:45 You can’t clamp over a paper label, Bruno…it’s …just…..wrong.
I was going to say the same thing... unacceptable!
duke1
Year and Model: 855 1994 10v
Has thanked: 416 times
Been thanked: 34 times
Post by duke1 »
454cid wrote: 17 Dec 2022, 21:01
hi most vw dealers have them,there on many vws theres even a vw tool for ease of removal,fitting is easy. audi ones are stainless atleast they where,good luck
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
Is that clamp strong enough for the coolant hose? Looks like it could blow right off? I use a rolled edge Norma Torr worm gear clamp for that. No, not Oetiker so I can easily remove it (most important for the lower hose to drain coolant).
FireFox31
454cid
Post by 454cid »
FireFox31 wrote: 18 Dec 2022, 20:58 Is that clamp strong enough for the coolant hose? Looks like it could blow right off? I use a rolled edge Norma Torr worm gear clamp for that. No, not Oetiker so I can easily remove it (most important for the lower hose to drain coolant).
The only time I've blown one off was when I pressurized the system with 60psi from the water hose (city water). If it hadn't blown, I probably would have lost my trucks radiator. I don't recall why I did it, but I was in the process of flushing the cooling system.
They have ears on them, but there's no way you're pinching it by hand enough to remove it. You have to use pliers and its best to use the pliers specifically designed for them.
The really great thing about them is that they adjust for thermal expansion, since they're a spring.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
FCP has the pliers
https://www.fcpeuro.com/products/hose-c ... s-cta-1050
Or you can support MVS via Amazon…
https://www.amazon.com/CTA-Tools-1050-M ... 164&sr=8-1
Great stocking stuffer!
Nice, I was thinking I would put my 850 or LeSabre in one.
A Thunderbird is roomy , but I don’t think either will fit.
bmdubya1198
abscate wrote: 19 Dec 2022, 01:12
:lol:
