Hi,
One of the things that probably kicks in is the notorious -2.2mv/degreeC voltage decrease. If the voltage decreases, the output voltage will decrease. To get to 21 volts we would need 30 cells in series. That's -66mv/degree C so over 50 degrees that's -3.3 volts. The MPP is typically around 18 volts so we are now below that already.
The interesting thing about charging batteries though is that the IV curve of a solar cell is pretty flat around the short circuit current level current. That means for a 1 amp panel at around 17 volts we would get about 1 amp, and at 12 volts we would get around 1 amp. Either of these, directly wired to a battery, would charge it at the same rate. The only way to get an improvement is to use a buck circuit that can convert the power at 18v to power at 12v and that would raise the charging current. The only problem there is that we would need a very high efficient buck converter to get any practical improvement. With a typical 80 percent efficient converter we would get hardly any improvement. It would take a 90 percent or better to make much of an improvement, and that means the converter has to be designed to fit the application almost perfectly as to input and output voltage and input and output current. This means an off the shelf max power point tracker isnt going to cut it, and neither is one that is rated for a much higher current than it will ever be used for.
There's a lot to consider if we are after the best possible solution. I guess i am after something near that but i wont be too fussy unless i have the time and energy to improve what i've got already, and it's usually simpler and more effective to just get a bigger panel. For now i am going to stick with a 20 watt (rated) panel and see where it takes me. It would be pretty amazing though to have a 200 watt panel that would really beef up the system. It may be too large for the inside of the car though (haha) unless i put it on the roof somehow.
