1999 S70 "AWD" Rescue Thread
- Has thanked: 316 times
- Been thanked: 531 times
I haven't had good luck with those wraps or cement on my Miata. The car sounds like hell with the rotted out stock exhaust. I really need to get a new cat back... I gotta talk to my parts guy and see if he has any nice aftermarket ones laying around.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
That's not an option here. There's a whole 2 inches of pipe missing. Ideally need to replace at 4 inch section of pipe.abscate wrote: 27 Aug 2019, 21:07 Both my 1999s have bandaged front muffler to cat joints for about 25 usd repairs. I used exhaust cement and fiberglass pack wrap on the joint
Knows enough to be dangerous
A missing piece is easier than a hole. Get to Advance and you can get Premade repair sections in the right diameter.
Cement up, slip muffler back, slip,repair on, two clamps.
It will last a year or two.
It is easiest to Jack the car up on one side at front and back as high as you can, jack stands or ramps of course.
- WhatAmIDoing
That's what I would have done, but I measured the OD at 62mm, roughly 2 7/16". The only thing that will fit over it has an ID of 2 1/2", but I think that will leave too much of a gap to clamp on properly.abscate wrote: 28 Aug 2019, 04:47 A missing piece is easier than a hole. Get to Advance and you can get Premade repair sections in the right diameter.
The silicate cement or glass wrap will fill that perfectly.
- WhatAmIDoing
Well... this took a dramatic turn. Driving home early Monday morning, going around a wet turn, felt the front wheels suddenly lock causing the car to spin out, nose dive into the embankment, spin around again, and striking a tree with the front passenger door.
Damage report: bottom of bumper ripped off, radiator sandwich mangled, fan shroud touching intake manifold, battery where intake is suppose to be, hood doesn't line up to close, 2 of 3 hood latches broken, all coolant leaked out, most of oil leaked out, both corner lights and driver headlight busted, passenger door mangled, rocker panel mangled, dash cracked, windshield shattered, A pillar looks deformed, both front axles mangled, transmission shot, bearings found on the ground... you get the idea.
Conclusion: Totaled, time to part it out like originally intended. Pictures to come later.
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
Sorry to hear. Hope you are OK ! Part it and be done !
Wow, that sucks! I guess a part out is the best option at this point, doesn't sound like it would be easy to get back together.
- WhatAmIDoing
If the A-pillar is bent, I'm not sure the frame is salvageable without compromising the structural integrity of the car. Even if the frame was intact, it would be much easier to find another volvo than find and swap in a new drive line. Got my eye on a rebuilt 144 and a 760 Turbo.
Oooh... a 144 would be sweet! And 760 turbos are pretty hard to find these days... either one would be cool!
- 1341 Views
- 40 Replies
- 4760 Views
Last post by E Showell
- 11 Replies
- 19465 Views
Last post by volvolugnut
- 14 Replies
- 2353 Views
- 68 Replies
- 9504 Views
Last post by manovlov
