scot850 wrote: ↑09 Feb 2023, 07:26 What I am asking is simply, how much does your solar panel output? If it outputs more than say 30mA to charge your battery , it should stop or at least match your cars normal drain from the battery. The whole point is as you are like me and don't now drive a lot, we use our cars less so we want the battery to be charged when we do use it.
So 2 simple measurements are needed. What is the drain on your battery in everyday sitting in your driveway? It should be around 10-20mA. If your 20W panel can supply at least that or more your car sitting should always have a charged battery.
Hi,
Oh ok that sounds good.
I dont know the actual drain on the battery when it is sitting because i cant measure it just yet. I dont want to disconnect the battery and my clamp on ammeter is made for higher amps, up to something like 600 amps, so the resolution wont be good enough to measure 20ma.
Does the panel put out enough to keep the battery charged? Well, up until today, yes. We've had several sunny days.
But for today, NO. Cloud cover keeps the energy from the panel very very low, and that makes sense because the insulation level is around 10 to 15 percent of what it is on a sunny day. There's no way to get even 50 percent power today because the radiation level simply is not there and it must be because of the cloud cover. It will be cloudy all day so i dont expect much.
For some quantitative data, the battery voltage usually starts out at around 12.06 now around 5 to 6am before the sun starts to come up and hit the panel. On a sunny day, it picks up to 12.35v or higher near around 11am. Today, it remains at 12.06v.
The insulation level on a sunny day can reach 650 watts/m^2 but today it's more like 65 watts/m^2. That's about 10 percent.
10 percent of 13 watts is 1.3 watts and that leads to maybe around 100ma charge current. I did not actually measure the current today though so it could be lower due to other factors.
Now that would seem like enough, but apparently either it's not enough (battery self discharge kicks in too) or it is actually lower than that due to other factors.
In any case, the voltage did not rise at all today, and although some current may be there it will not be enough to take it over the period of darkness tonight. Normally the voltage will rise and then when it gets dark the voltage falls gradually until about 6am when it is around 12.06 volts. If it starts out at 12.06 volts, then it will fall much lower by tomorrow morning.
So to find out about what you are suggesting i'd have to measure some current levels, but im not sure if it matters. If the voltage during a cloudy period does not rise as much as during a sunny period, then it's not enough.
The only thing i dont know yet is will the voltage even hold at 12.06v or will it rise to 12.07v or fall to 12.05v before complete darkness.
