454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
MoVolvos wrote: 06 Mar 2023, 22:50 Once you loosen it, just before it starts to drip slip a bag over it and move the rubber band all the way to the top of the thin grocery bag before spinning. The S70 changed to the cartridge, not sure when in the later models and that does not spin freely as the gasket is in contact with the threads all the way down.
Yeah, this was a first for me, with the cartridge inside the reusable plastic housing. I think it's kinda weird, as it's like going back to the 50's small block Chevy, although I never changed one of those, I remember seeing it mentioned in magazines about converting to spin on.
The Volvo must keep some oil above the filter, as I got a small flood as soon as the o-ring was free. I had assumed I'd be able to pull it down without spilling. That might have happened with the 850 spin-on too.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1503 times
Been thanked: 3817 times
1999 turbo models went to the plastic housing and insert. NA kept the metal 917 filter.
P2 went to the insert in 2001
Has thanked: 1846 times
Been thanked: 1710 times
My 00 NA had a plastic filter. The metal OE Volvo filter has a non-return valve in it to keep the top end primed with oil. There are many aftermarket ones, but no idea which ones have the valve included. Maybe Mann?
454cid
Post by 454cid »
Washed the S70! Well, just drove it through the automatic car wash really. I'm not big on hand washing, especially this time of year. I also vacuumed out the driver's side foot well.
I need to top off the anti-freeze, and check the oil. I noticed the coolant looked down a little the other day, and I haven't verified my oil is fully topped off since changing it, Sunday.
On sunny (but still wet/cold-39F) days like this, I look longingly at the 850 that's waiting for me.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Stay warm! 75 and sunny here today... hoping this sticks around!
454cid
Post by 454cid »
abscate wrote: 07 Mar 2023, 15:52
Just realized that looks like negative 39. It was above zero, not below....actually reached low 40s.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Post by 454cid »
bmdubya1198 wrote: 07 Mar 2023, 17:18 Stay warm! 75 and sunny here today... hoping this sticks around!
That will be so nice!
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 327 times
Been thanked: 87 times
Post by CIK7 »
Today I worked on the rear shocks.
I removed the first shock mount bolt on driver side. Sheared it off. Remembered on stuck bolts, Robert loosens then tightens then loosens again to prevent shearing. I did that on the 2nd one and worked fine. Both on passenger sides did not get stuck. Went to hardware store to buy 4 new flange bolts and a cobalt drill bit. Came home and installed new passenger side shock mount with blue threadlocker. Drilled out half of the sheared screw before running out of ample power in drill batteries. Took a 2-4hr break. Came back out and finished drilling out the sheared screw. Definitely nicked the chassis threads. Removed brake caliper and rotor to adjust emergency brake and reinstalled. Removed old driver side shock and replaced with new one. The nicked bolt hole was still good and accepted the new bolt with blue threadlocker. Finally new shocks and mounts means I finally got the volvo back on the road! I ripped down east main st! Soooooooooo fun! I have more tasks to complete soon. Non-working horn and rear windows might need regulator swap.
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
abscate wrote: 07 Mar 2023, 02:59
My 00 S70 Base / NA has the cartridge :?: I wish it was the metal can.
