Has thanked: 1505 times
Been thanked: 3818 times
Completed all new cooling group hoses on Shagg
Top bottom radiator
Reservoir pipe
Heater hoses
All oetiker clamped
Power steering hoses oetiker clamped
Flushed and fresh coolant in Shagg
abscate wrote: 14 Jul 2023, 15:30 Completed all new cooling group hoses on sahgg.
Top bottom radiator
Reservoir pipe
Heater hoses
All oetiker clamped
Worked through the exception sheet on Shagg
Checked coolant system for leaks
Installed air guide
Installed last rear muffler hanger ( removed to remove drop pipe )
Installed TB cover
Installed rear engine mount and hanger
Took her for 30 minute spin on the highway with ac blasting cold
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Decided to check my AC today after driving the car the other day with what felt like seriously under performing AC. Checked the low side pressure, and it was only around 21 PSI running... pretty low for 90ish degree ambient. Took a whole 340 gram can, and now it's icy.
Poor AC in NC in July…..oooof. Glad it perked up!
bmdubya1198
abscate wrote: 16 Jul 2023, 05:17 Poor AC in NC in July…..oooof. Glad it perked up!
Yeah, that wasn't gonna cut it. It's been a hot, humid week.
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
bmdubya1198 wrote: 16 Jul 2023, 09:26
I really need to replace my A/C clutch. About had to break out the scuba gear this week. And I now own(ed) 3 P80s with seized sunroofs.
bmdubya1198
WhatAmIDoing wrote: 16 Jul 2023, 21:34
Long as they’re not leaking sunroofs… not much worse than that!
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
I'm jealous of all you with your functional A/C. I've got to replace A/C systems on two 2000 V70s at some point. I bought all the parts for my original V70 but it got wrecked, now they'll go to the next one. I started researching the job years ago and have a tome full of notes. But first, I have to get the cars running correctly because that's more mandatory than A/C.
And I've got to get my two sunroofs to stop leaking. I have a full assembly as a spare. Was planning to swap it in to one car, rebuild the leaky metal on the one I removed, and install that into the other. But I found a local source for non-leaking sunroof glass so I'll just get another panel.
But darn I wish I had A/C.
FireFox31
Are you doing your NE cruising sans AC?
You need to stop at Stony Brook AC Specialists soon
Probably need Evaps done, dash out but stupid monkey wrench work, not horrible
WhatAmIDoing
bmdubya1198 wrote: 16 Jul 2023, 22:28
Unfortunately, the S70 leaks under heavy rain.
