Has thanked: 1850 times
Been thanked: 1712 times
Check the drains have not split an the 4 corners of the sunroof cassette. Not uncommon as the plastic tube gets brittle with age. Also check they are not blocked and backing up.
When I was getting a leak that I blamed the sunroof for, I found it was actually a leak through the windshield. It would only do it when the rain fell from a certain direction and the car was on a slope. Made it harder to find!
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
scot850 wrote: 17 Jul 2023, 14:04 Check the drains have not split an the 4 corners of the sunroof cassette. Not uncommon as the plastic tube gets brittle with age. Also check they are not blocked and backing up.
Based on the corrosive evidence, it is leaking between the glass and the metal frame.
A bead of silicon in the short-term around the glass to metal joint may be ugly but may prove the theory.
Has thanked: 1506 times
Been thanked: 3818 times
Ran over to Lowes to get wood for project , got free air for the right front tire, left rear went flat from a nail or blowout, TBD
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
The free air at Lowe's is a nice touch. I guess they realized guys show up on the way to the job site and overload their trucks that already have 21 PSI in the rear tires.
Luxury! I have never seen that here in Canada at a Lowes, which is now reverting to Rona (yet another failed US company in Canada).
That does make sense if you have a load you have picked up and you need to run your vehicle or trailer tires higher. Nice touch indeed!
bmdubya1198
I only just started seeing them in the past few months. I wouldn't be surprised if they made their way up north soon!
Crank , no start on Shagg this morning.
I let battery droop so needed a jump pack this morning. Cranking was about 80% of normal but no firing. Could hear fuel pump start , but could not hear ETB initialization.
Before I tore into it, I put it on a 4 amp charger for 30 minutes while I got some groceries
30 Minutes later , bump…Vrooom
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1001 times
Post by volvolugnut »
Another data point telling us Volvo engine crank is not a good indicator of enough Volvovoltage for starting.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
abscate wrote: 18 Jul 2023, 06:56 Crank , no start on Shagg this morning.
Before I tore into it, I put it on a 4 amp charger for 39 minutes while I got some groceries
30
Low pressure on the electric hose.
