Has thanked: 1497 times
Been thanked: 3810 times
One thing I don’t like about the metal filters is on lightly used cars the top of the filter rusts out. I’ve had two of these cars blow out oil filters on cold starts from top filter failure, using Wix filters. Water pools on top and does it’s damage there. I have rolled the o-ring on the insert type once , that makes a nice mess, too.
I make a note to change the metal kind out annually even on low use cars. Naturally, the FreeCP program makes that easy on the running cost.
Has thanked: 1836 times
Been thanked: 1709 times
I just don't like the rubber 'O' ring on the newer paper element plastic cup. It is way too easy to snag the ring. I lightly oil the ring and just turn it slowly and if I feel any binding stop and let the 'O' ring settle and then continue. So far so good, but not something I enjoy. With the metal ones, never had a Volvo one rust out on me. Only issue is when some knucklehead cranked them on so tight that it took the old screwdriver through the can to get it off as the filter wrench just crushed the can!
Anyway, it is what it is.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
scot850 wrote: 26 Dec 2023, 08:31 I just don't like the rubber 'O' ring on the newer paper element plastic cup. It is way too easy to snag the ring. I lightly oil the ring and just turn it slowly and if I feel any binding stop and let the 'O' ring settle and then continue. So far so good, but not something I enjoy. With the metal ones, never had a Volvo one rust out on me. Only issue is when some knucklehead cranked them on so tight that it took the old screwdriver through the can to get it off as the filter wrench just crushed the can!
I really wonder how/why people crank on those spin-on filters so tight. Get it nice and tight by hand, and that's it. Never put a tool on those to tighten them. Seat it, then 1/2-3/4 of a turn. Done!
When done properly, you should be able to remove them by hand. Occasionally it'll take a wrench to break it loose just from pressure/heat cycles tightening it up, but if you have to go full barbarian on it, the last guy screwed up!
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
bmdubya1198 wrote: 26 Dec 2023, 09:22
I have to remind myself of that every time as the sealing is the O-Ring exerting pressure to the side of housing. There is no mating/sealing surface at the top as with canister filters. Muscle memory and old ways are hard to change especially when in a hurry.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 128 times
Post by 454cid »
abscate wrote: 26 Dec 2023, 04:22 One thing I don’t like about the metal filters is on lightly used cars the top of the filter rusts out. I’ve had two of these cars blow out oil filters on cold starts from top filter failure, using Wix filters. Water pools on top and does it’s damage there.
I was going to check for that, last time I did the oil on my 850, but I had used a smaller diameter filter the previous oil change. I don't recall there being rust when I had the larger diameter filter the previous time. I wonder if I still have that filter kicking around. It would have been a Mahle. Now the car has a fullsize Baldwin on it, but since I'm not driving the car in the salt, I'm not expecting any rust.
Thankfully, I have not done that. It's something I'm a little nervous about, and therefore quite conscious of the risk when I'm doing the job.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
You will feel it if it’s out of place. The plastic cap won’t screw in nicely by hand.
weitau
Year and Model: 2004 V70
Has thanked: 7 times
Been thanked: 2 times
Post by weitau »
I put the underbelly cover back on today, after confirming my oil filter leak stopped. I also received a parts shipment from Rock Auto today. It was a Power Steering Reservoir Line Hose and Thermostat. I looked at the position of my V70 NA 2.4 engine, and said there's no way I'm going to try to take it off. The lower torx bolt is tucked behind the thermostat housing and blocked by the power steering pump.
2004 V70 2.4L
weitau
Post by weitau »
Almost forgot - I got front-ended by a Gen 2 Sienna backing up to get a parking space (a rarity in NYC). I saw the reverse lights come on, but never thought they would knowingly back right into me. My license plate screws put two dents in her rear bumper (which appeared to have been replaced), but my V70 didn't show a scratch.
2004 V70 2.4L
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
Is there any way to know if your car originally came with an underbelly cover? From what I see online it seems that it's uncommon.
Also is there supposed to be a cover between the bumper and subframe?
What I did today was use the car to bring stuff to a storage unit and I've discovered that my key doesn't work on the tailgate and passenger side locks. I'm not sure it's a changed barrel because the tailgate turns when the car is unlocked. Are there common jamming issues here or a way it can be reassembled wrong?
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
454cid
Post by 454cid »
weitau wrote: 26 Dec 2023, 19:01 I put the underbelly cover back on today, after confirming my oil filter leak stopped. I also received a parts shipment from Rock Auto today. It was a Power Steering Reservoir Line Hose and Thermostat. I looked at the position of my V70 NA 2.4 engine, and said there's no way I'm going to try to take it off. The lower torx bolt is tucked behind the thermostat housing and blocked by the power steering pump.
What is it that you wanted to remove? The thermostat is easy to change. I have one to do to. I've not touched the power steering on either of my cars.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
