Has thanked: 1848 times
Been thanked: 1710 times
I recall you talking about you AWD 850 manual. Very jealous!
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Yup, that's the regular gloss white. Platinums were only the Turbo trim level.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
FireFox31 wrote: 19 Jan 2024, 20:10 I replaced the two dipstick o-rings on my 2000 V70. Now the stick is held in the tube quite firmly. When I apply the significant force to pull out the stick, I think it splashes oil around, throwing off the dipstick reading. Has anyone experienced and solved this problem?
Lubricate the O-Rings with silicone grease and twist slightly, right and left as you pull the dipstick. The grease can take a lot of heat.
Randomnamegenerator
Year and Model: 1996,850 AWD
Has thanked: 1 time
Post by Randomnamegenerator »
scot850 wrote: 21 Jan 2024, 12:21 I recall you talking about you AWD 850 manual. Very jealous!
Yes the very same :)
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
Had to remove the rear seat bottoms and now I'm wondering, what are those red tabs for? The small lever things that attach to the same cross bar.
I also "converted" my tailgate trim to use wide pads of adhesive instead of clips. Hoping it lasts.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
RedBrickCollector wrote: 22 Jan 2024, 23:57 Had to remove the rear seat bottoms and now I'm wondering, what are those red tabs for? The small lever things that attach to the same cross bar.
Those are the latches holding the seat cushions in the car. Unclipping them allows removing them completely.
RedBrickCollector
foggydogg wrote: 23 Jan 2024, 07:57 Those are the latches holding the seat cushions in the car. Unclipping them allows removing them completely.
Something might be broken on mine then, as they don't seem to have any effect, I can pull them out either up or down. Thanks.
'97 950 T-5 Wagon
There is a cheap repair kit for repairing the tailgate mounts. Skandix probably sells it. Volvo sells one but they do not include the clips to remount the inner cover, the aftermarket one usually does.
bmdubya1198
scot850 wrote: 23 Jan 2024, 08:32 There is a cheap repair kit for repairing the tailgate mounts. Skandix probably sells it. Volvo sells one but they do not include the clips to remount the inner cover, the aftermarket one usually does.
You just have to be really careful installing those, since it's VERY easy to just shatter the plastic.
I carefully use a small drill bit to predrill the holes to prevent breaking the plastic. You could then use JB Plastic glue and reinforce the repair.
