Transfer case question('01 V70 XC)
shwayz
Year and Model: 2001 V70 XC AWD
Has thanked: 1 time
Post by shwayz »
Hey, I've got a 2001 V70 XC AWD and I'm replacing the old transfer case(Part #01023739) with a new(to me) identical one. However, in my research, I found that the original part number for the 2001 transfer case is #36000338. Is there any meaningful difference between the two, like gear ratio, spline count, etc? Would it still work?
Has thanked: 2209 times
Been thanked: 1852 times
According to Volvo of Vancouver website the part # 36000338 only fitted 2001 and 2002 S60/V70 AWD and V70XC
https://www.volvovancouverparts.ca/p/42 ... 00338.html
The other part number you listed is not shown as a Valid Volvo part number. Are you sure that is the correct part number? Volvo often have a part number stamped on a casing but that is the casing part number and not the whole item part number.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Companion flange is different, if memory is not lying.
