Well back with a more major inconvenience.
The brake fluid tank has been emptying recently and i have not noted any pools of fluid on the ground. Hoping its a torn brakeline near the wheel. This thread is to document the process.
The peddle has an intermittent stiffness, and recently it feels like the brake peddle holds firm and holds the car, then 20 seconds later it feels the calipers loosen out.
Guess i get to do my 6 month mechanic visit on time this year.
Brake Fluid Loss Thread - 1998 V70 Endless fun Topic is solved
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
2008 S60 2.5T Auto (Sold)
- Has thanked: 2209 times
Do you have a strange smell in the cabin of your car? The master cylinder can leak into the brake booster. This can also affect the vacuum to the booster which will give you a hard pedal.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
+1, what Neil said.
On some non-power assisted brakes the stuff can end up saturating the carpet.
The pedal going away is diagnostic for an internal leak if you don't see any on backing plates, &c.
You folks may suffer from rusted brake lines someplace other than the four corners too.
- Has thanked: 987 times
- Been thanked: 1078 times
Brake leaks are typically slow and you will not see puddles, but a wet cylinder behind the wheel. Crawl under with a light and look closely. Bad brakes scare me like nothing else.
- Has thanked: 1611 times
- Been thanked: 4072 times
After each brake fluid change , no more than 24 months apart, I put. A sharpie mark on the brake fluid level. That level should not change unless you are driving 20-30000 miles
yanga001
To add, previously ive seen wetness below the master brake cylinder which i assumed was just me spilling fluid. Ill take a good look later today and see if i can pinpoint the failure. Keeping an extra bottle of dot4 (1L) in my car now.
Hoping its a quick or easy fix in terms of resources. Did 5 alternator swap motions over the last 2 weeks until i finally made my rebuilt last. Now this, man i love this car. Estimated 6k a year on gas but no cars are available now
. The front logo fell off my car on top of this so gotta take it with a smile. Will post updates later today
yanga001
I did notice a smell a few days back that smelled like brake fluid when the issue first came up.scot850 wrote: 10 May 2022, 08:36 Do you have a strange smell in the cabin of your car? The master cylinder can leak into the brake booster. This can also affect the vacuum to the booster which will give you a hard pedal.
Are you AT or m56? The clutch system pulls fluid from the same reservoir so that can be a leak if you waggle the shifter for r gears
yanga001
Automatic transmission. Will post a pick of the master cylinder and reservoir after work.abscate wrote: 10 May 2022, 14:24 Are you AT or m56? The clutch system pulls fluid from the same reservoir so that can be a leak if you waggle the shifter for r gears
- 1418 Views
Last post by Mokomaki
- 58 Replies
- 7960 Views
Last post by mrbrian200
- 13042 Views
- 11 Replies
- 19529 Views
Last post by volvolugnut
- 518 Views
