random symptom: starting from parking the idle hesitate, run erratic and drops to the point of stalling--looks like the engine is coughing-It gets better if I accelerate but not moving from parking-There is no check engine light and no engine codes
I replaced spark pugs and coils-air filter --no fix
I always use premium gas and synthetic oil
I suspect is MAF or fuel filter?
start up hesitation 2006 S60 2.5 T FWD 140k Miles
- ignatz
- Year and Model: 2006 S60 t5m
- Has thanked: 18 times
- Been thanked: 33 times
Or possibly the fuel system is loosing pressure, or bleeding back somewhere. A strong dose of Chevron Techron "could" clean something in the fuel system that's sticking. Sometimes it takes days for that stuff to work. At least the Techron will be working to fix your car, while you try to figure out the problem.
Sad part is, this stuff was $5 last year at WalMart, now its $10.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
2005 S60 2.5t awd
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
No, fuel adaptation. Engine computer constantly monitors oxygen sensor sitting right behind exhaust manifold and adjust air-fuel mixture accordingly.
https://trade.mechanic.com.au/news/unde ... uel-trims1
Now you need to trace your fuel delivery. These generic codes don't tell everything, with DiCE+VIDA you can diagnose it more precisely. It will even show your fuel pump's duty cycle, which may tell you whether the pump is dead or the problem is somewhere else.
