Volvo XC70 2000 Stalling in gear
madeesawnv
Year and Model: 2000 XC70 SE
Has thanked: 1 time
Post by madeesawnv »
hi, i have read countless posts that sound similar to my problem, but none are exactly what i am experiencing.
My Volvo xc70 2000 SE starts, idles, and revs normally. when i try to put it in drive or reverse, it will stall immediately. i am able to restart the car, but never able to put into gear without stalling.
the last day i drove it (which was also the first time i ever experienced an issue) it stalled at a red light, and i was able to shift into drive by revviing engine while simultaneously shifting into gear. (i had to repeat this process every time i came to a stop.)
the revving is no longer an effective workaround for the stalling issue.
that night, looking under the hood, i discovered my fresh air intake had become detatched from the turbo inlet, and that was promptly replaced. but the stalling persists.
i have since replaced the MAF sensor, and just put in a brand new throttle body from Xemodex..
any input would be very much appreciated..
the car has 165k miles on it, and has had virtually no issues since ive owned it.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
Could this be ignition related?
If my ignition parts are well worn, sometimes the car will almost stall when put in D or R.
1996 855 R,
2010 V70 D5,
Has thanked: 1609 times
Been thanked: 4065 times
Track the entire path of the air intake looking for loose clamps or hoses that have Holes. Any leaks will cause this. Usually, you have to remove each piece , inspect,and replace, to find these faults. Simply looking , won’t suffice
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Listening might though. If the leak is big you should be able to hear it.
BMW 540i 2002
S70 Base 2000
madeesawnv
Has thanked: 1 time
i inspected all the hoses, i did not find any cracks or holes, though they are a bit crumbly? on the outer layer. i tightened all clamps and made sure everything was on where it out to be. any other suggestions going forward??
Has thanked: 2199 times
Been thanked: 1852 times
How good is the battery on this car? If the voltage is low they can not start or run terribly.
What happens if you disconnect the MAF and try to start/drive the car?
madeesawnv
Has thanked: 1 time
the battery is fairly new. i replaced it in the fall. it has no trouble starting at all and can stay in P or N forever if i let it
the MAF is brand new but i could try , ive got nothing else to go off of.
i was thinking of doing a transmission flush, or at the very least drain and fill.. though i have not experienced any other transmission symptoms. i am a little desperate. haha
What brand is the MAF? Volvo OE or Bosch?
madeesawnv
Has thanked: 1 time
it is bosch, i had purchased a volvo oem but it got stolen out of the trunk of by some vultures who broke in :((( the things people steal these days .
