Bookmark
Partslist to follow
New 4/22
Front struts - Sachs 533 058 - @90 = 180
Spring seat - Sachs 803 066 - @46 = 92
Bearing plates - Sachs 31200599 - @60= 120
Swaybar endlinks - Meyle 30714686 - 30
CV joint boots - Rein BKN 0045R - @20 = 40
RF hub - ENKIDU 513174 - 65
Front rotors - Brembo 25344 - @75 = 150
Front brake pads - ATE 31341243 - 50
Front brake hoses - ATE 3546813 - @28 = 56
Hatch struts---------------Stabilus 5B-3958IA
Hatch card clip repair kit
1998 V70R 428 Coral Red /26
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
- foggydogg
5/22
Air filter --Mann C35148
Oil filter (oil)--Mann W917
Cabin filter--Mann CU26250
Fuel filter
Trans fluid flush
Brake fluid flush
Gear oil (F+R)
Rear T/S bulbs
R/F T/S assembly
Hatch latch plate ........Volvo 9485477
License plate mount....Volvo 31391626
Lug bolts-Alloy x-20.....Volvo 3546899
Fuel filter
Trans fluid flush
Brake fluid flush
Gear oil (F+R)
Rear T/S bulbs
R/F T/S assembly
- foggydogg
5/22
RF motor mount -- Volvo 9480189
Upper torque bush - body -- Volvo 8631159
Engine bracket -- Volvo 9434263
ABS Matty module
Wipers
-W/S
-Rear
-H/L -- Volvo 274435
ABS Matty module
Wipers
-W/S
-Rear
- foggydogg
5/22
Rear rotors
Rear pads
Parking brake shoes
Parking brake cables
--- retainer clips Ford 8M-2814
Hardware kit
Hardware kit
- foggydogg
5/22
Harvested from Poor Old Blue
RF CV stub axle
Lower control arms
Hatch latch
Power steering pump
RF CV stub axle
Lower control arms
Hatch latch
Power steering pump
- foggydogg
6/22
Oil cooler lines delete plate 1366780 (Thanks, Robert rspi)
Belly plate/center bearing support 9474483 $165.49, but shipped free Couldn't find one used, neither could Robert.
- foggydogg
Timing belt kit Volvo 30758261
Replaced brand new Dayco belt/uknown tensioner/idler @149,165
Serpentine accessory belt ( Continental 6pk1743 ) too tight; Volvo 9186352 on 8/16
Spark plugs Volvo 8692071
NGKs had good color but were finger tight
- foggydogg
- Has thanked: 2200 times
That is such a pretty car! Looks awesome.
