Volvo V70R hard steering
jakebvrs
- Year and Model: Volvo V70R 2004
- Has thanked: 1 time
Well I came across a dime of a car on facebook market place but she came with some flaws. Traveled on down to maryland after a 6 hour car ride to pick this V70R up. It has some flaws but nothing major. Something I cannot stand is the hard steering, I want to say it’s the clock spring but all the control work and the horn works. But something I hear is a clicking noise when i turn the wheel and then when it gets into a certain position it’s super easy to spin around. It has the chasis light up and im not sure if that would be a problem. Can someone please point out the obvious to me, there’s power steering, car isn’t leaking and isn’t rough just god awful steering which is giving me a forearm workout.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
I had hard notchy steering. It ended up being the lower steering U-joint and the steering rack were both bad. Spray some PB blaster on the lower u joint and see if that frees it temporarily. Replace immediately if that’s your problem because a bad one can cause the pinion seal to fail and that’s a new rack.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
raise it off the ground, try disconnecting one tie rod at a time to remove load from ea side.jakebvrs wrote: 04 Jun 2022, 13:08 The car only has 149k on it plus the car hasn’t been driven in like 4 months so it’s just been sitting. I’ll try looking under and seeing what’s going on with the car.
- 1065 Views
Last post by PS78
- 1584 Views
Last post by fontoledo
- 1452 Views
Last post by oragex
- 22 Replies
- 3083 Views
Last post by thomas larsen
- 49 Replies
- 7302 Views
