Hi there,
So what do you think?
Jack the front wheels up on a FWD car and run the routine drive cycle or whatever is needed to get the monitors ready.
Think this will work or will the computer sense that there is too low of a drive torque and not do any monitor testing?
If it did work it could help solve my current problem, which is getting the monitors to go ready.
Drive Cycle With Front Wheels Jacked Up
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- Has thanked: 311 times
- Been thanked: 817 times
Are you sure you even need the monitors ready?
I thought most (all?) states gave exemptions for monitors on a 98 Volvo. I know CA does and they seem the most restrictive.
I think no- torque will be problematic. Might work on a - 1998
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
This is gonna sound crazy but when I was having emissions readiness problems I got a bluetooth obdii reader and paired it with the torque pro app. You can configure to monitor the emissions readiness and just drive around until they all read "ready". I found a couple of places that would let me bring the car in and do the emissions testing without shutting the car off. That's the only way I can pass. However mine is a 1996 and now I only have to do safety inspections in Texas. My issue was the monitor reset on every startup. I never solved it unfortunately.
- MrAl
Hi,erikv11 wrote: 15 Jun 2022, 13:43 Are you sure you even need the monitors ready?
How did you find that out?
I read on the New Jersey site that cars 1998 are allowed 2 monitors not ready but that coul dbe for other cars.
How would i find out otherwise?
- MrAl
Oh that's a strange one. I wonder why that happens.ZionXIX wrote: 15 Jun 2022, 19:58 This is gonna sound crazy but when I was having emissions readiness problems I got a bluetooth obdii reader and paired it with the torque pro app. You can configure to monitor the emissions readiness and just drive around until they all read "ready". I found a couple of places that would let me bring the car in and do the emissions testing without shutting the car off. That's the only way I can pass. However mine is a 1996 and now I only have to do safety inspections in Texas. My issue was the monitor reset on every startup. I never solved it unfortunately.
The problem with this car is it takes several startup and shutdown cycles to get the monitors to flip to ready. Usually i just drive around in my usual routine of going to the store and a few other places and the go ready. That takes about a month or two i think. This time i am a little pressed for time because inspection is due end of month.
The policy is set by the states , following EPA guidance at their discretion. The NJ DOT website would be definitive hereMrAl wrote: 16 Jun 2022, 02:48Hi,erikv11 wrote: 15 Jun 2022, 13:43 Are you sure you even need the monitors ready?
A simple weak battery orbadatteryvcable(s) causing voltage to drop on cranking, would reset the monitors on restarts
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
I used to have a real nice smog guy checking my car. Sometimes if the monitors weren’t complete he would take care of it running the car on the rollers in the floor. He obviously knew the drive pattern for a Volvo, maybe they are about the same for other cars as well?
EDIT: I take that back. My BMW goes through all checks really quick compared to a Volvo.
EDIT2: Engine must be cold when starting to drive. Think I missed that a couple of times and had to redo it all over again.
BMW 540i 2002
S70 Base 2000
- ZionXIX
My monitors will fully set on a 20 min drive to work everyday. No paying attention to any of the drive cycles.MrAl wrote: 16 Jun 2022, 02:51
3p141592654
- Year and Model: 2000 V70
- Has thanked: 3 times
- Been thanked: 3 times
The weak battery resetting the monitors on cranking bit me one year. If cranking voltage dips below 9V during cranking you likely will have trouble.
- 38 Replies
- 8084 Views
Last post by wizechatmgr
- 17 Replies
- 4094 Views
Last post by swedehast
- 831 Views
Last post by matthew1
- 67 Replies
- 5201 Views
Last post by MrAl
- 320 Views
Last post by bluewagon
