I checked my oil level a few months ago, had some rusty sludge and thought nothing of it, maybe air pressure or something spontaneously manifested moisture in there. I go to check my oil again but the stick is rusted in place and the handle's popped right off. What could this be indicative of?
If I remember correctly, this could indicate a cracked engine block, where the coolants mixing with the oil - which would also mean my engines very quickly on track to becoming a very large paperweight, right?
Any clarification or links for further reading appreciated, Thanks!
850 95 Dipstick rusted shut
- Has thanked: 146 times
- Been thanked: 559 times
Do you drive the car much? A lot of short runs produce condensation in the engine. If you do not get the engine good and warm then you are likely to get condensation/rust. The 850 dipstick is known to break. You can remove it by removing the whole tube. I think on the 850 there is one either 10mm or more likely 12mm headed bolt on the front of the tube bracket into the manifold and then it can be removed complete.
You can then remove the dipstick by forcing it out of the top from the bottom.
The replacement dipstick I think is different so you need the tube and the dipstick. Make sure to get both parts correctly as the markings for levels are different.
Removing the tube will allow you to see if there is water in the oil. If there is, are you losing coolant? If so it may only be the radiator leaking into the oil cooler pipes if it is a turbo.
2006 XC70
2006 XC70
- Has thanked: 181 times
- Been thanked: 522 times
Like Neil says, probably you can just replace the tube-dipstick combo.
'96 855 NA, 147k
'98 V70, T5 tune-injectors-turbo, LPT engine, 294k
'06 S60 R, 172k
'07 XC70, 189k
'99 Camry V6
138k
gone: '96 NA 850 210k, '98 NA V70 182k, '98 S70 NA 225k
'96 855 NA, 147k
'06 S60 R, 172k
'07 XC70, 189k
'99 Camry V6
- Year and Model: 1996 850
- Has thanked: 20 times
- Been thanked: 5 times
It is not a turbo, Base model manualscot850 wrote: ↑29 Jun 2022, 18:45 Do you drive the car much? A lot of short runs produce condensation in the engine.
Have had the same ~ 15m weekly commute for 3 years, this has only been apparent the last 3 months. I checked the coolant from the reservoir, it doesn't look lower, but would it even be noticeable? How would I be able to tell from taking the tube off? (Also, if I take the tube off, is it just going to start peeing oil out its new hole?)
- Sveedy
- Has thanked: 154 times
- Been thanked: 168 times
So when did you last change the oil ? If you have coolant in the oil, I'd think you see it at that point. Frankly it seems like you'd have to have a lot of coolant in there to cause a rust problem. Like Scot850 mentioned - condensation most likely.
Unbolting the dipstick tube and pulling it won't cause you to lose any oil. The stick protrudes out of the tube a bit, and the O-ring is even further up on the tube end.
- foggydogg
- Has thanked: 47 times
- Been thanked: 123 times
If the level in the coolant tank hasn't changed, I think you're OK there, it is likely just condensation.ToriWhite wrote: ↑30 Jun 2022, 16:55It is not a turbo, Base model manualscot850 wrote: ↑29 Jun 2022, 18:45 Do you drive the car much? A lot of short runs produce condensation in the engine.
+1 what Neil said; unless you can find a good dipstick at a junkyard, you will need the tube assembly. The oil level in the pan is lower than the bottom of the tube. If you haven't done so in a while, get a new gasket for the oil fill cap, that could help keep condensation down.
Regardless of the miles, if the oil hasn't been changed in some time, this might be a good time for a maintenance cycle.
97 850T5 project
98 V70R, Junkyard rescue
62 122s four door, 2l, FI head, discs up front, ipd swaybars
97 850T5 project
- foggydogg
My old 850 had developed that crusty look at the top of the dipstick, I cleaned it up and put fresh o-rings on it - and the fill cap gasket - and that solved the problem.
97 850T5 project
97 850T5 project
- Has thanked: 785 times
- Been thanked: 2142 times
If you are pulling the dipstick and tube, definitely replace the o-rings if you aren’t replacing it with new
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
- foggydogg
The o-ring/gasket at the bottom of the tube seems to be the same part number through the years, but as mentioned, there is an engine number break on the dipstick itself. When you get the assembly out of the car, you may be able to get rough with the remnant piece, and once the tube is cleaned up, just replace the dipstick itself.
97 850T5 project
97 850T5 project
- 655 Views
Last post by misha
- 26 Replies
- 2864 Views
Last post by xHeart
- 15 Replies
- 5632 Views
Last post by cn90
- 14 Replies
- 1826 Views
Last post by volvolugnut
- 29 Replies
- 1778 Views
Last post by cn90
