v70 manual - reverse R is gone after accidentally engaging instead of 4th?
bg212
Year and Model: 2001 v70
Post by bg212 »
So accidentally, instead of 4th gear, at about 35mph, the car was put into reverse. Releasing the clutch was accompanied by a loud grinding noise. That happened twice before person realized it was not 4th.
So now the reverse does not work. Releasing the clutch, something click in the tranny, the car does not move.
Even while not in motion, with the released clutch, you can easily put it into reverse.
I would not think the splines on gears are sheared, as that grinding noise indicated the splines did not engage even when the clutch was released.
2001 v70 t5 (must be a m56 transmission).
I maintained the car rigorously myself for many years. Feels bad.
Any tips?
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
No responses yet so I'll chime in.
1. I'm not a transmission expert, but I have been working on cars since 1974 and spent 28 years in the International automotive industry as a product development engineer/manager/director. I may be dangerous with what I don't know...but I have owned a 2001 T5 5 speed (M56) since 2001.
2. I'm assuming all forward gears are still working properly. Just reverse doesn't engage.
3. With the car moving forward in 3rd gear @ 2000-3000 rpm's, the driver tried to make a low speed gear go in the opposite direction twice. I'd surmise reverse gear teeth are busted. All it takes is a few .
4. I think you are going to need a used transmission or need a transmission specialist tear it down to determine why the reverse gear isn't engaging. Tough decision for a 21 YO car.
If you drain your manual transmission oil, you may get a idea of how much metal is floating around in the transmission.
Good luck. Hate to see a Volvo classic head to the JY.
Has thanked: 1610 times
Been thanked: 4068 times
I’ve yet to find anyone on the internet in North America who rebuilds these or a source of internal M56 parts
It’s a Borg Warner build.
I think sourcing a used one would best
I never searched under BW…..I’ll be GD!
https://www.borgwarnertransmissionspecialist.com/
Oooof, Cardiff might be a bit far
bg212
Post by bg212 »
thanks for replying all. Yes, I started looking at dismantlers / junkyards listings for a used gearbox. I think it is the only option.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Try erie volvo in NY.
https://www.erievovo.com/
bg212
Post by bg212 »
^^ they don't have it. But thanks anyway.
I yesterday found one in Sacramento and placed an online order. Hope to pick up tomorrow. It has 100k miles less than my car (> 240k).
I tried today driving it. I should say the rest of the gears are not the same as well (i.e. occasionally much harder to engage, or something clunking going into the gear). The 5th is briefly grinding when put into it and when the clutch is fully depressed.
To be fair, the last few years I observed some deterioration in shifting quality, i.e. it's like gears slightly catch some metal edge when shifting in. Even though I did trans fluid flush, and it got better (i.e. second was hesitating going in), the net result was negative. So, hope everything is for the good.
Also, I haven't done transmission before, so naturally have questions:
* do I need to replace something along the way, like rear main seal? Anything else comes to mind while I am there?
* the clutch - (on Acura, or BMW e46 it's a self-adjusting clutch) is it self-adjusting on Volvo? I.e. would I need to somehow re-setting it before re-installing?
Or any tips are welcome (i'll search the forums too).
93SCMax
Post by 93SCMax »
Once again, not an expert, but if you are going to drop the transmission, definitely replace the clutch and rear main seal if not done earlier.
Hopefully someone with manual transmission experience will chime in.
sebrenite
Year and Model: 2004 V70R , 2008 C70
Post by sebrenite »
bg212 wrote: 04 Jul 2022, 13:51 Or any tips are welcome (i'll search the forums too).
I have not worked on this transmission, but many universals apply, such as:
-Rear main seal (Cheap insurance)
-Release bearing and clutch slave cylinder (Replace or inspect and grease as Volvo recommends)
-Pilot bearing
-Transmission fluid
-CV driveshaft seals for differential (inspect/replace CV boots if needed)
-Axle bolts (don't forget dust seals)
You can measure the clutch/plates to see if they are within spec. Many will say to just get a clutch kit that includes some of the above ( Release bearing, pilot bearing)
https://www.ipdusa.com/products/6754/Cl ... 314-114755
https://www.rockauto.com/en/catalog/vol ... h+kit,1993
Look for a kit with everything including grease and alignment dowel.
Screenshot 2022-07-07 170353.png (218.29 KiB) Viewed 3969 times
bg212
Post by bg212 »
Yep, I got everything: Valeo clutch, seals, etc except dust seals. But I need to make a trip to a dealership for one bolt and a clutch line o-ring (those need to be replaced among many others bolts / nuts), so will get dust seals too.
I don't think there is a release bearing on v70, as the slave clutch cylinder is internal, vs external (like on BMW) with a fork and a release bearing.
I also purchased a new DMF flywheel which needs to be replaced when the clutch is replaced (and my car has over > 240k miles so it must be long due). However, I purchased LUK which is not the most expensive one, but I used LUK SMF/clutch on BMW (which is OEM for BMW) and have no complains.
