Mitsubishi, Rotomaster or Erie
CedBobKing
Year and Model: 06 V70, S40, 07 S40
Has thanked: 9 times
Been thanked: 3 times
Post by CedBobKing »
I am considering replacing the turbo in my V70. I believe that it has been seeping a little bit of oil for a while. The three best options seem to be a Mitsubishi OE from FCP Euro, a unit from Rotomaster, or a used one from Erie Volvo with under 100k. Does anyone have any experience with the last two options.
There also seem to be several Chinese options out there. Is that a result of Geely buying Volvo? Might one of those be a good option. Do they put this turbo on new engines?
Thanks,
Cedric
2006 V70 2.5T 279,000 miles
2006 S40 2.4i 95,000 miles
2007 S40 2.4i 105,000 miles
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
I installed a new cartridge in mine, comes all balanced, from the UK, $185 on ebay.
But oil leak is usually just the gasket at the top of the drain tube.
Swap out the seal at the bottom end of the drain too. $7 fix.
On mine the shaft was snapped in half.
Its much easier to just swap out the cartridge, no messing with the exhaust manifold.
https://www.ebay.com/itm/313999737908
