My 96 850 glt is having issues stalling. The car will run fine for a few miles then begin to run rough then stall. I wait 15 minutes then drive it a few miles to home. I have replaced the MAF (reset the parameters) spark plugs, cap, rotor, wires, checked for emission leaks and replaced hoses. It happens most when the air conditioner is on. I checked my alternator and discovered that it was putting out 12.78 volts. I am going to replace it but could this really be my issue? Any thoughts?
Thanks
96 850 glt stalling issue
- Has thanked: 2210 times
Have you swapped out the Fuel pump relay or checked fuel pressure?
- Has thanked: 1611 times
- Been thanked: 4074 times
You definitely have a dead alternator , or possibly a bad cable between alternator and battery. A weak battery can cause stalling
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Drive the car for 30min and let it idle,do not turn the engine off.
First check voltage output directly on alternator.
Positive probe on b+ and negative probe on alternator housing.
Compare voltage output on battery terminals.
If battery terminals are shoving lower output than alternator...then your positive battery cable is bad and needs to be replaced.
Healthy charging system produce 13.8-14.2v at idle with headlights,radio and heater blower ON at 1st or 2nd speed.
Perform a voltage drop test if needed on both...positive & negative side.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 7738 Views
Last post by enriquepr21
- 1623 Views
Last post by jjs70pdx
- 977 Views
Last post by WhatAmIDoing
- 17 Replies
- 4812 Views
Last post by 850corb
- 1580 Views
Last post by E Showell
