The transmission is not working at all. I have the front end raised/front wheel off the ground. Transmission indicator is working, shift cable attached, but no forward or rearward tire rotation when put in D or R. Geartronic / manual shifting no result either. Scanned the car with Vida and no codes.
Does anyone have an idea what to check next?
Current milage 185k but the transmission was replaced by Volvo under warranty at 100k by the previous owner.
The transmission developed a shift flare with 3-4 shift since the last 3 weeks, did a drain and fill and added some lubequard, did not help. It has an external atf cooler and magnafine filter.
2006 Volvo V70 FWD transmission not working at all, no codes
Rvolvos
- Year and Model: 2006 xc70
- Has thanked: 73 times
- Been thanked: 23 times
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
2012 S60T6 95k rip
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Do you have a whining sound? How long did the “flaring” go on? Might be you smoked that clutch pack and pump is beginning to whine because the filter got clogged. Sounds bad, like a brokrn hard part
BMW 540i 2002
S70 Base 2000
jking4020
- Year and Model: 1997 850, 2001 v70xc
- Been thanked: 3 times
If it went out after the extra chemicals you put in id do a complete drain and fill. Then another and maybe another. Not all additives are good for our cars. Change filter of course. Does it feel like its going into gear but still does nothing?
Rvolvos
Flaring, 1 or 2 months, no whining sound at all.
I agree with a broken part, because it is doing nothing at all
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2012 S60T6 95k rip
Rvolvos
Used Lubequard because it was recommended by other users. It is worth a try, but If that would be the case, I would at least expect the tires to turn when off the ground, without a load.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2012 S60T6 95k rip
