In other parts of this site someone mentioned replacing an old ETM with a contactless 2013 ETM. This would be great as the PnPs in my area don't care what the specifics of the part you pull, just the general label that it is an ETM for about 30 bucks.
Does anyone have a compatibility list for newer to older cars. I have a 1999 S70-GLT (2.4L) engine. Would any 2.4L, 5 cylinder 2013 ETM let's say from a S60 work on this older car? Would the VIN need to be programmed into the ETM?
Thanks for any insights you might have
Compatible 2013 contactless ETM for older S70?
- 800artfreed
- Year and Model: 98 S70T5; 99 S70GLt
- Been thanked: 26 times
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
- Been thanked: 4064 times
The newest version apparently has software that works with both turbo andNAcars.
So far , I am 3/3 with a drop in replacement with no software.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
What does 3/3 mean in this context? You have the part, but not the software and thus can't use it?abscate wrote: 27 Jul 2022, 02:53 The newest version apparently has software that works with both turbo andNAcars.
dikidera wrote: 08 Dec 2022, 12:38What does 3/3 mean in this context? You have the part, but not the software and thus can't use it?abscate wrote: 27 Jul 2022, 02:53 The newest version apparently has software that works with both turbo andNAcars.
3 installed later ETMs. 3 successful installs with no software needed
lrock
- Year and Model: 2001 v70 xc
- Has thanked: 9 times
- Been thanked: 37 times
Will these drop into a 2001 v70, or is it just <2000 ?abscate wrote: 27 Jul 2022, 02:53 The newest version apparently has software that works with both turbo andNAcars.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I'm curious about this as well. What years are switchable ?
1999 V70 GLT
1999 V70 GLT
The Magneti Morelli style Electronic Throttle Module was only used on 1999,2000 models (up to 2004 for the C70) and more models in EU, like LNG cars.
A 2001 in North America will use the Bosch Electronic Throttle Actuator, it’s a completely different technology, all together
- 2440 Views
Last post by 800artfreed
- 54 Replies
- 3822 Views
- 1871 Views
Last post by goVolvo
- 4810 Views
Last post by Hoofbaby
- 2587 Views
Last post by doublebug
