97 850 GLT E85 questions
jboncher01
- Year and Model: 1997 850 GLT
- Has thanked: 3 times
Wondering if while doing upgrades such as turbo and turbo manifold ecu tune and different injectors if running e85 tune could be an option.
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 114 times
Yes, I run E85 on mine.
If you get a tune from Vast (the best M4.4 mapper you can find) you have the option to get two maps, one for gasoline and one for E85. You can switch them "on the fly", afaik he's the only one that does this.
Just remember that E85 needs more volume (about 30%) for a given amount of energy, so you might need bigger injectors/fuel pump. Obviously range on a full tank will drop.
I'd also recommend changing fuel filters once or twice after you start using E85, it's pretty good at getting crud unstuck from the tank.
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- Has thanked: 2200 times
One thing to be VERY careful about is E85 damages fuel hoses of the rubber kind! Make sure any rubber sections of hose are compatible.
- 12 Replies
- 4680 Views
Last post by Cptinc
- 206 Views
Last post by koralski
- 3580 Views
Last post by ChrisatXeMODeX
- 14 Replies
- 2275 Views
Last post by dosbricks
- 778 Views
Last post by Clemens
