One of my friends has a 99 V70Xc with failed rear shocks. They are not nearby so have asked for a picture so I can identify if they are Nivomats or not. I am 99+% they will be as it was a wagon AWD and don't believe they came with plain shocks.
Now I have looked but can't see anything, but I was sure I read of someone fitting standard type shocks to an XC. There is a 00 S70 AWD in the local PnP which I am certain did not have Nivomats fitted which may mean they could be fitted the the 99 XC potentially.
There is also a 98 XC there and the Nivomats are still there, but the boots are shot and I believe they are no longer available as I recall from foggydogg's trials on the subject.
Anyone able to shed light on this?
Thanks,
99 V70 XC rear shocks question
- Has thanked: 2203 times
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
I'll look under my '00 XC when I get away from the VA tomorrow. It's still jacked up under the tree after the failed belly crossmember experiment.
I've also been fiddling with a boot workaround for the dust gaiter, but it got put on a higher shelf during my wrestling match with the R.
And the 2nd Nivo you sent me is still on that same shelf.
My list grows longer daily, it seems.
I hear you on the never ending and lengthening list................!
Appreciate your help.
Did you ever order and receive the rubber bellows/boots? They are supposedly on back-order and the local dealer says they take about 4 weeks to get here. I was thinking of ordering a set to see if they show up as I do know of a set of Nivomats for an XC but their bellows are shot.
- befarrer
- Year and Model: 1998 V70 AWD
- Has thanked: 1 time
- Been thanked: 24 times
If they are nivomats, and you change to regular, you would also need the springs. The issue with the xc models is they are higher.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
Thanks befarrer. Appreciate the reminder as I had forgotten about the spring thing.
I am hoping they Nivomat boots are still available as these are just to help the owner to sell the car on in a working condition. She is a mechanic and removed them for her daily but is now moving on to a newer Volvo (XC60).
- befarrer
I did remove my nivomats, and have OEM Volvo non Nivomats shocks in their place, and Lesjofors springs claiming to be for a V70 AWD without self leveling suspension, and the ride is much smoother, especially for back seat passengers. My AWD is not an XC though.
98 V70 GLT AWD
05 VW Golf TDI
05 VW Golf TDI
I do find the Nivomats can be a little hard when there is no load in the rear of the car, but they are great with a load.
V70XC AWD has different ride height at the rear with different hubs and shocks to the regular P80 AWD.
- foggydogg
Tried my luck ordering the boots again,
" Thank you for placing your order with Tasca Parts!
While reviewing your order (Order 1794648) for processing I've discovered an issue. Part #1387105 is currently on national backorder with the automotive manufacturer and has no estimated date of resupply. We do not currently have this item in stock at our warehouse and are unable to acquire it at this time. Unfortunately, despite our best efforts, sometimes the demand for certain parts and accessories exceeds manufacturers’ current supplies. I apologize for the inconvenience.
To prevent any further inconvenience, I have canceled and refunded your order. Please allow 5-7 business days for the refund to clear.
Hopefully, we can better serve your OEM parts needs in the future!
Thank you for your business!
Kind Regards,
Amy C "
Kind Regards,
Amy C "
- befarrer
Sounds like a lot of stuff in the world today. I work at a Volvo truck shop, we are having the same issue, common parts on backorder with no eta.
98 V70 GLT AWD
05 VW Golf TDI
05 VW Golf TDI
