98 V70 GLT - Turbo Coolant Inlet Pipe part number?
KHolden
Year and Model: 1998 V70 GLT
Has thanked: 3 times
Been thanked: 2 times
Post by KHolden »
Had a coolant leak from the turbo coolant inlet hose. Once I had the old hose off I could see the turbo inlet pipe had a huge hole in it. Looks like Volvo put the hose clamp on way too tight and cracked the pipe and it's been wearing away for the last 24 years.
Anyway, I can't seem to find the part number for this pipe anywhere. Anyone have suggestions where I can look? Or do I have to try and find a junk yard? Or possibly is there a way to repair it? I'm half considering just putting the new hose clamp on the other side of the hole and rolling with it.
Image Pasted at 2022-8-9 09-19.png (959.84 KiB) Viewed 480 times
rrres
Year and Model: 1999 v70XC
Has thanked: 12 times
Been thanked: 34 times
Post by rrres »
Seems to be a common rust spot on those pipes. The one on my 99 wasn't rotted out but it is heavily rusted in that same area. I have one I pulled out of 2004 C70. It has rust in that area also but not rotted out. Will that one from the c70 work? if interested, send me a pm and I'll send pics.
It's blowby
KHolden
Post by KHolden »
I finally found the part number, it's 1397793. Found a listing for a new one for $33 so I think I'll just bite the bullet unless they can't get it to me in a reasonable amount of time. Really appreciate the offer though and will definitely take you up on it if this vendor doesn't come through.
Cheers
(This is where I found it btw: https://www.bostonvolvocarsparts.com/p/ ... 97793.html)
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
From Vida
For some reason the -98 inlet pipe seems readily available from the usual OEM resellers (tascaparts, volvopartswebstore...) at around 30$, but the 99+ one is discontinued :?
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
