2002 v70 tighten ball joint
toshgregg
Year and Model: 2002 V70 2.4t
Has thanked: 1 time
Post by toshgregg »
bought a cheaper ball joint without spline socket in spindle and I cannot tighten the nut, spindle just spins. Jacked up control arm but still no luck, any ideas short of taking it apart and using a new joint with spline socket?
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
You are telling me you installed a ball joint in the control arm, but it spins? It sounds to me like it wasn't pressed well.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Try an impact wrench, FYI the Volvo ball joints do not have a spline on the taper bore either. I assume you are talking about the large nut on the end of the balljoint?
2003 XC 70 (sold)
toshgregg
Has thanked: 1 time
Post by toshgregg »
Thanks guys, I already tried impact wrench, no go there?
dikidera
Post by dikidera »
Every single car I've seen has never had splines on the ball joint, the ball joint has a taper which when pressed in the knuckle well will hold it from spinning. Hammer it in from bellow.
deano1
Year and Model: 2001 s60 1999 awd
Has thanked: 13 times
Been thanked: 17 times
Post by deano1 »
He's talking about the torx "spline" Lemforder used on the bolt part of the ball joint. Sometimes you need to use this torx if the lock nut Lemforder supplied overwhelms the ball joints resistance to turn in it's socket before the nut is able to pull it tight to the control arm.
You all know this is amplified by 1000 if you're trying to remove that ball joint :wink:
cheers Dean
Blacklab467
Right, or use a channel lock plier or vice grip to hold the knuckle to the lower control arm, failing that, use the torx at the bottom of the ball joint spindle.
2003 XC 70 (sold)
toshgregg
Has thanked: 1 time
Post by toshgregg »
Thanks everyone, I put a large pry bar between ball joint & spindle hub and pulled and tightened nut to specs
Has thanked: 1610 times
Been thanked: 4065 times
You have to make sure that taper isn’t spinning. I made that mistake on an E83 and halfway home had a loose strut. Drove home at 45 on back roads , checking every 10 miles.
