Mann W917 oil filter on 99 ( non turbo)
Has thanked: 1610 times
Been thanked: 4069 times
My two NA 1999 use metal spin on filters. Theis is a Mann 917 after 12 months in rust belt , one winter.
Top rust is a bit nasty, I’m a bit sensitized to it because when I first started Evita the can let go and Exxon Valdezed my driveway
Sticking to 12 months or less for filter changes in the rust belt is probably prudent
markone
Year and Model: 2007 V70
Has thanked: 21 times
Been thanked: 14 times
Post by markone »
Ooooh, good tip. Thanks!
2006 V70 NA/manual trans, 165k
2007 V70, NA/manual trans, 143k miles
2023 BMW X1, 29k miles
2018 Jeep Grand Cherokee LTD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 395 hours
1997 850 Sedan NA, manual trans, sold at 330k miles
1998 V70, NA/manual trans, sold at 365k miles
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
I suppose you could do pre installation painting of the filter to slow the rust. While protecting the seal area, of course.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
That's weird. I'd guess it's the position of the filter, right up front and straight up and down, so it has plenty of opportunity to catch water and salt, and then holds onto it. My other vehicles have the filters further back and/or tilted, so they don't allow for anything to sit on top.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 2205 times
Been thanked: 1852 times
If only the P80's came with under trays under the engine like we had in Europe. Kept the engine bays a lot cleaner and less of this type of issue. I wonder if they never came to North America due to engine heat issues as they would reduce air flow around the engine in hot areas. At least it would have been nice to have the option...........! :(
P80's did not have engine trays but all 240's did? Strange.
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
I originally read the title as Mann W917 oil filter on 99 NLA and freaked out a little
Changed title to ease anxiety. It is is used on both white block and red block Volvos so it isn’t going anywhere.
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
I'd just brush a thin layer of marine grade anti-seize on the bare metal area.
