850 power steering fluid drain and fills.
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
To my surprise my power steering fluid was dirty, smelled burnt, and had metal fragments in it. It was last flushed when rack and pinion was replaced, about 5 years ago. Pump has always been a bit noisy but most people haven't noticed or commented. I did a litre of drain and fills with Redline 75w only because I had it on the shelf, according to it's specs it's compatible. Anyway, I generally don't think of PS fluid as something that needs regular service but maybe now I will keep a closer eye on it. Volvo manual says IIRC no servicing required!
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
The flush procedure by MadeInJapan works very well. It's a very controlled process because the fluid only circulates when the wheel is being turned. I think I ran two liters through the system before the exiting fluid was nice and red.
FireFox31
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
My 2 cents on PS system: Clean fluid is a must, and I've also had a Magnefine inline filter on the return hose for over ten years. 333K on original rack so far. Seems to work really well. Any hydraulic system should have a filter in my opinion. Otherwise it's just an exponentially aggravating cycle of wear. I have one on the trans return line as well.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- 39 Replies
- 7310 Views
Last post by BlackBart
- 30 Replies
- 27079 Views
- 6092 Views
Last post by EngineeringBloke
- 13 Replies
- 6086 Views
- 19 Replies
- 9456 Views
