Clicking noise coming from engine (2002 v70)
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
After I put the engine back together after replacing the head gasket, and after a few weeks, I started hearing a ticking noise coming from somewhere. I have attached a video file with the noise. The noise only happens on idle, and goes away when driving or reving. I think it happened because I put something together wrong. It sounds like it may be coming from where all the pullys and belts are.
volvoNoise.m4v- (4.43 MiB) Downloaded 142 times
2002 v70 X/C 288k miles
- 02V70
I pulled the cover and didn’t see anything different happening when there was a clicking noise. However, I did notice it only happens when the A/C is on. I can’t really tell where the noise is coming from, but it doesn’t sound like it’s coming from the compressor. I attached a video showing the noise coming and going with the a/c compressor.
Img 1174.m4v- (6.25 MiB) Downloaded 103 times
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
To me it is a viberating sound from plastic material -- loose belt cover housing, not properly fastened. A careful look at the edges of the belt may not be a clue, but the belt tensioner may provide a clue.
Engine Timing Cover Casing:
