Hallo
I have bmw e36 and i want to swap volvo engine,i have 2 T6 engine's but there is no chance to start them with original ECU,so my question is what engine with turbo can i use and make it run with standart ECU?I want 2.3 T5 but is it possible to make immo of to some of the original ECU that they use?
BMW e36 with volvo engine
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
You can adapt the '98 M4.4 ECUs. There are available binary files with the immobilizers removed that you can start with. I would think anyone able to handle an engine swap such as this would be able to deal with the wiring, etc. You could make use of a stock engine-side harness from one of the Turbo 850's or a '98 MY S/V/XC 70, and there are a few connections needed on the body-side harness.
Another option is a stand-alone ECU, such as MaxxECU. This could also work with your 6-cyl options.
- 1957 Views
Last post by Krons
- 1785 Views
Last post by xHeart
- 1467 Views
Last post by SuperHerman
- 1490 Views
Last post by mamajack123
- 2441 Views
Last post by jimmy57
